Engine identification question
I have read lots of threads on engine numbers so I decided to check my car today.
According to my log book my car has SPY0nnn as chassis number and N269nn for engine number.
When I checked my car today the chassis number is correct - the chassis was changed in April 1983.
The engine number is different to the log book - the car history shows it had a “complete recon engine” in October 1982.
Can anyone shed any light on this engine number that I found under the painted block?
Many thanks
Many thanks
- Chris-72sprint
The chassis number doesn't relate to the actual physical chassis so a new chassis shouldn't change the VIN plate. Looks like someone gave the DVLA a Spyder number, that is stamped on the chassis. Did they also insist on a 'Q' plate?
- mikealdren
No fortunately - it’s still got it’s XRA765L plate but I agree this was not a good move.
I may try and get body number back on logbook
The engine number confuses me
- Chris-72sprint
The log book engine number does not appear to relate to a standard Lotus number but your current engine number stamping does., so it looks if a Lotus block was used for the rebuild whne previously it may not have had a Lotus block from a previous rebuild. If that's an Elan or Plus 2 engine number others here can tell you where it came from mainly except for gaps in the records if its an ex Cortina or Escort engine or one of many racing blocks I dont think they have those records
Chris, the engine number on the block appears to be LP8880. Engine numbers in this sequence were being fitted to cars in late 1967. It does not correspond to an Elan in my records.
However the number appears to have been scratched in, whereas Lotus punched in the numbers on the block, so I would view the number with a degree of scepticism at this stage.
The Engine No on your document is much more likely to be the correct one for your 1972 Sprint, as it corresponds with others of the same time.
Regarding the chassis number. Although that may be the nomenclature on the log book, the correct and unique identifier for your car is the Unit No, the last four figures of the full VIN plus the letter E in your case, denoting a FHC.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
trw99 wrote:Chris, the engine number on the block appears to be LP8880. Engine numbers in this sequence were being fitted to cars in late 1967. It does not correspond to an Elan in my records.
Hi Tim
I have seen engines with scribed engine numbers rather than stamped that appear to otherwise be original Lotus blocks so maybe Lotus lost their stamps for a period.
Ford blocks, at least the 120E ones I have seen here in Australia tended to have a number stamped on the boss ledge above the oil pressure sensing tapping but some also have a number scribed in the boss above the engine mount that may be a little different from the stamped one on the pressure tapping boss ledge. Maybe Ford had some scribed identification during production and then stamped a final number when it was mated to a car and at times at least this scribed identification was also used for the Lotus number on blocks destined for Lotus. Impossible to know and it's a pity no one from the Ford engine line at this time appears to be around to understand better Fords production practices in general and for blocks destined for Lotus in particular. It would also be nice to know whether Lotus or Ford ground off the casting numbers on the earlier blocks in the 66 to 69 time frame approximately and why
What number is stamped on the back end of the head facing the bulkhead
- alan.barker
Hi Tim
Thanks for info
My body number is 0492E
Engine number in log book (suspect the original) is N26970
Car was originally Lotus Yellow/white sprint
Registration XRA765L
Do you have any details in your records
- Chris-72sprint
Craven wrote:Very interesting, looks as if the Engine number ends with AA, can you tell us these identifying numbers/letters especially those encircled in red.
Hope you can see this ok
- Chris-72sprint
alan.barker wrote:What number is stamped on the back end of the head facing the bulkhead
I think the number is 9673 ?
3 digits with camera behind head
4 digits with mirror/camera
Difficult to get there with engine in car
- Chris-72sprint
If it's the original head then that is the number of original engine.
Let's see what the record holders say.
- alan.barker
Chris-72sprint wrote:trw99 wrote:Chris, the engine number on the block appears to be LP8880. Engine numbers in this sequence were being fitted to cars in late 1967. It does not correspond to an Elan in my records.
Hi Tim
Thanks for info
As follow up I agree my engine number looks suspicious
I have taken another picture and it looks like part or all the original number has been ground off and new digits scratched on - those 8’s look like X’s - Alan asked about the head number - it looks like 9673 or 9623.
Any thoughts/info appreciated
- Chris-72sprint
Hi Craven
The numbers on my block that you have circled are 4J4 which I think means 4th September 1964 or 1974.
Where the block in the picture you sent has numbers on the right mine seems to just have a “L” close to the clutch end and a “T3” higher up to the left.
The number on the back of the head is 9623.
Does any of this point to which year/model this engine comes from ?
- Chris-72sprint
OK thanks for that extra info, the circled code is the casting date for that block, I would have thought that would be 1964. Block type will tell us for sure, are the large numbers at the other end, that is 120E, in my pic, visible or has it been ground off. By 1974 the block type is quite different identified by a casting ‘projection ‘that accommodates a dipstick used on Escort etc.
Interest in your engine number ending with AA was that the usual Lotus numbers end with LBA but some selected and over bored blocks ended in LAA.
Head number 9623 would be for an engine mid 1967.
- Craven
