Elan S4 - Plastic/metal sleeve on intake valves
Can someone please help understand what those sleeves are for? Found them over all my intake valves.
I cannot find them in the workshop manual and apparently one of them already started disintegrating.
Many thanks in advance!
Max
Max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
these are valve stem seals, to prevent oil to go down to the chamber when the valve guides are worn out causing smoke.
There are two main approaches for these oil leaks
- guides should be within specs and the little oil going down the stem is actually good for stem lubrication, this should last a long time and when it smokes because of that the engine actually needs an more complete overhaul than just the seals (also with higher lift than stock it is difficult to impossible to properly install seals)
- modern engines do not use that much oil and thanks to seals the smoke and oil consumption can be reduced
I'm an advocate of the first approach.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Thanks for the quick and useful response.
I will also go with the first approach.
Max
Max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
No seals, versus seals has a lot to do with the materials used for the valves and the valve guides. In the early days valves were steel and guides were often cast iron. They needed some oil for lubrication. Bronze alloys didn't stand up to the high temperatures and wear, and seal materials which can live at these temperatures were not yet developed. Now we use 214N stainless steel valves running in guides made from fancy bronze alloys, which wear better, dissipate heat better, and we know how to make seals which usually live in these conditions, so the modern valvestem/guide interface doesn't require as much lubrication. We can add seals which improve performance, and emissions, so we do, as long as the physical space is available at full cam lift. If your engine is already set up for them, then they are definitely worth keeping. Your engine will burn better and run cleaner.
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
Some interesting stuff about valve stem material versus valve guide material here.
https://calverst.com/technical-info/val ... and-usage/
I've pulled down crossflow engines in the past fitted with valves having oversize stainless steel stems running in the original cast iron guide and the results certainly weren't pretty.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Users browsing this forum: 69S4 and 23 guests
