Sprint / Big Valve Cam Cover Question
i all
Another question - as big valve engines were sold in the USA, but were equipped with Strombergs what cam cover was fitted? If it was the ribbed Big Valve version, did it have the bridge pice cast into the inlet cam side to take the little 'L' bracket for the throttle cable?
Thanks in anticipation
Matt
Matt
Visit me on matthewvale.com
Matt Elan - Fourth Gear
Matt Elan wrote:i all
Matt
I have a TC Europa, red ribbed cam cover but no throttle cable mount, which was incorporated into the secondary throttle / inlet manifold casting.
RogerFrench - Fourth Gear
Mine has a bracket screwed on to one of the valve cover studs which I think I’ve seen on quite a few others, the second one I added to capture the cable for the bonnet release that’s on the right hand side, Gordon Sauer
- Gordon Sauer
Here’s mine, but it’s on Weber’s so doesn’t need it
- Bigbaldybloke
Thanks guys I think we can assume there was just the single design of ribbed cam covers.
