Engine breather
Noticed some have extra/better breather out the front top of the chain case, really the valve cover I believe.
Rather, is the oil filler cap not preferred. As caps are probably inexpensive compared to a valve or chain cover?
Kind Regards
Kind Regards
Love your Mother
Earth
Love your Mother
Earth
The issue is about not carrying over to much oil with the blow by gas. The front of cam cover breather does not result in to much oil carryover as there is a reasonable oil disengaging space inside the cam cover at this point. Venting the blow by gas through the filler cap would result in a significant amount of oil carryover due to the oil mist in this area from the cams unless some oil disengaging items were included in the design - could be done but simpler to just vent at the front of the cam cover
Someone recently had posted a picture of their rear left of the engine plate. The plate was to reduce oil splashing up & out the filler cap.
I will search for the picture, I suspect this may a good answer.
Thanks Rohan
Thanks Rohan
Love your Mother
Earth
Love your Mother
Earth
I suspect you'll still get a relatively high amount of oil coming out with the vapor from that location even with a plate in place. Personally I'd only consider it a good testing location to see if increased breathing is needed.
Personally I am consider some experiments around the routing of the standard breather to a venturi in the air box intake area to see I can find/create a low pressure spot to use to increase the flow via the standard breather out let. Not sure if/when I'll get around to this thou.
- mbell
Users browsing this forum: elans3 and 27 guests
