Coolex radiator Plus 2
PostPost by: NYK » Fri Jan 31, 2020 7:28 pm
Who’s fitted one of these Coolex rads to a Plus 2, I have a question or two.
http://www.coolexperts.co.uk/product/lo ... struction/
NYK
PostPost by: NYK » Tue Mar 03, 2020 8:29 pm
Well I’ve fitted one now
0A51F34F-25FD-4CF0-B2D5-0451DC6A0837.jpeg and
NYK
PostPost by: pptom » Tue Mar 03, 2020 10:05 pm
That's one seriously shiny and tidy engine bay!
pptom
PostPost by: Chrispy » Tue Mar 03, 2020 10:06 pm
Looking good! Did you have any issues fitting the radiator?
And did you buy your brake servo as a kit? i've still got the Mk2A which I'm having issues with and looking at the Lockheed units. Haven't seen that front bracket before.
Elan +2 #0245
Exige S2 Supercharged
Chrispy
PostPost by: NYK » Tue Mar 03, 2020 10:32 pm
Fitting the rad was OK as I was lucky enough to find a fellow Plus 2 owner locally and was able to take some measurements off his car. Because I’d fitted a complete new front end I had no pre-drilled mounting bracket holes in the body, so needed some accurate measurements. The rad comes with the mounting flanges pre-drilled and I believe it is meant to line up with the existing brackets. I did need to slightly adjust the mounting flanges but that was just a case of filing a few mm off the lower sides, no big deal.
The Lockheed servo came with the main bracket which I used, but the front bracket did not really fit where I needed it to so I turned up a stainless steel collar to fit the servo and attached that to a threaded rod and simple bracket also in stainless
NYK
