Look what I found
I am replacing my sump because it has a hole in it so I dropped it down and found this arrangement.. It is a swiveling oil pickup secured by mounting to the front and center main bearing caps. I know Dave Bean has something similar in his catalog. Probably overkill on a street engine.
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
It's not overkill. It's well designed and works as advertised, even for a street Elan that is driven like intended. The windage tray helps reduce the pumping losses and the swinging pickup keeps your oil pump and bearings well supplied.
If you don't want it, please let me know. I'll take it off your hands.
Dan
Dan
i would take two please, and maybe a third in case one fails
does it follow lateral forces? going around a LH corner, will it swap to the left side of the sump? and visa versa!
Love your Mother
Earth
Love your Mother
Earth
According to Bean it follows centrifugal force and gravity hence it follows the oil.
67 Elan +2
67 Elan +2
- seniorchristo
Besides the very cool oil pick up, I?ve noted the well done safety wiring job. Somebody built an engine to good specs.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Obviously, this has become a weld the hole in the sump and replace. I also see if you've managed to get the sump completely off the engine, you must have a removable crossbrace. I'll bet there are other trick bits to your car.
Oh, and if you decide to go back to stock oil pick-up, I'll be happy to take it off your hands, I'll even figure out how to pick it up. But I really think you should keep it for yourself. You might also figure out how to copy it and make a bunch of copies.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
I also have it on one of my Elans. I am not sure it is the Bean version as this car was built by Spyder in the UK. But it is a swinging pickup. Next time I have it off the car, I will look into having it reproduced.
Tony V
Tony V
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
ElanGTS, 93 Caterham, 05 Elise,
99 Elise190, 05 Elise, 2005 MiataSpeed Turbo
tvacc - Coveted Fifth Gear
Is a baffled pan as adequate
For fun street, actually. The motto here is. Find out where the limits are, and start from there.
Love your Mother
Earth
Love your Mother
Earth
Those with a loss of oil pressure complex, have you seen this type of thing, seems a very simple solution.
https://www.demon-tweeks.com/uk/canton- ... er-500619/
- Craven
I tried patching the hole a couple of times with epoxy. It would hold for a while but eventually the epoxy cracked and would leak again profusely. I added the removable brace, a piece of steel channel from McMaster car that adds .9 pounds of weight I have a used sump I'm putting on but just realized my 711 block requires wider rubber strips to seal the ends of sump. I'm going to leave "swinger" in place for the time being.
67 Elan +2
67 Elan +2
- seniorchristo
Thou most dont realize
Everyone wants a ?swinger?
Love your Mother
Earth
Love your Mother
Earth
Craven wrote:Those with a loss of oil pressure complex, have you seen this type of thing, seems a very simple solution.
Seems a very expensive solution.. but for racing, fine.
JonB - Coveted Fifth Gear
https://www.summitracing.com/int/parts/ctr-24-006
They are quality
1/2 the price of the UK/EU for Canada
They are quality
Love your Mother
Earth
Love your Mother
Earth
