DCOE 40 151 & 45 152 Venturi removal tip
Again another discovery I hope I am not repeating but will be of help someday
While trying to sort a over rich mixture, I dismantled the carbs and in this case WEBER DCOE 40 151 ( new style Spanish carbs with addition adjustment.
I discovered the Air By-Pass Screw item 26 actually goes through a hole in the Venturi (Choke Tube) item 22 and you need to remove the Air By-Pass Screw item 26, I bent my by-Pass screws not realizing they are an interference fit
LOTUS Evora 400
Ginetta G27 S2
66 one-off 2.6Ltr v8 Mid-engine Berlinetta Coupe........... in restoration
..................................................Age doesn't matter unless you are a cheese................................................
Ginetta G27 S2
- au-yt
Thanks, Yes I should have mentioned #28 as its the Aux venturi retainer
LOTUS Evora 400
Ginetta G27 S2
Ginetta G27 S2
- au-yt
Users browsing this forum: pianoderby and 12 guests
