Relay in addition to starter solenoid?
The PO of my car (S4 with BDP) had installed a regular relay between the key and the starter solenoid.
The starter is a Tilton Super Starter hi torque.
I've never seen this previously. Before I remove the relay, I wanted to see if maybe the Elan key switch wasn't up to the current required by the solenoid or if there was some other issue that I wasn't aware of.
Thank you!!!
-Kyle
Thank you!!!
-Kyle
'70 S4 Elan - Cosworth BDP & Spyder Chassis
'62 S2 Super Seven Cosworth
- disquek
Are you sure the po has not put all the Cables on th same Terminal of the Original Starter Solenoid to use as a Terminal Block. I think the Tilton has an internal Solenoid. The Relay is to stop too much power going through the Ignition Switch.
- alan.barker
Maybe fitted to get around old wires and connectors resulting in sufficient voltage drop, especially when hot, resulting in failed start.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
The inductive nature of the solenoid activating coil tends to make the starter contacts on the ignition switch spark and burn, so fitting a relay as described lengthens the lifetime of the ignition switch.
Relays are cheaper and more readily available than ignition key-switches.
I think there have been bits of debate on this already (I'm rather tired now to look it up).
I'm hoping to use a relay to the intergrated solenoid on my starter motor (I have no old loom for reference and have not looked up the details).
Could someone sketch up a diagram showing the best solution that does not damage the ignition switch or the starter by any chance ? Recommendations on relays would also be very appreciated !
Many thanks
Many thanks
- Frogelan
