Hart breather
• Page 1 of 3 • 1, 2, 3
I would like to fit a 'Hart' breather to my cam cover.
I know they are available from one or two suppliers but I'm not going to pay ?55 for what is essentially a plumbing fitting!!
Could anyone direct me to a suitable off the shelf fitting which will do the job and, also, suggest the best location to place it on the front of the cam cover?
Jon
Jon
- jono
When I took my breather off , just fitted a brass plug..
but before that just had a 22mm compression elbow screwed in ( just the elbow ) with a 1" pipe leading off to a catch tank.
I've used a similar breather for many years. It fastens with epoxy, and makes a tidy, leak proof installation.
And no, I didn't pay that kind of money.
- elancoupe
David/Mike,
Where did you obtain the fitting please?
I've just rebuilt my engine due to oil leaks and I want to do all I can this time to try and make it dry. I don't like the idea of the rubber oil drain tube being the only crank case vent
Jon
Jon
- jono
Do I have this wrong? Surely a breather should be a larger bore?
Do you have the full length shaft in there?.spraying oil onto the breather ?
Users browsing this forum: 69S4 and 27 guests
