Help Identify This Strange Noise Please
My S3 started to make a chinkachinkachinka type rattling noise on the drive home tonight.
It?s intermittent (of course!) but before I jack her up and start ferreting around I thought I?d see if the collective wisdom of the forum had any ideas.
45 second video with sound attached.
It seems to be something towards the bottom of the engine bay, I don?t think it?s from within the engine itself.
https://youtu.be/z4ctx7M02xE
Thanks in advance all
Best
Best
1967 S3 SE DHC
1970 +2S (RIP - went out in a blaze of glory in 2001)
Stevie-Heathie - Third Gear
I had a similar noise that turned out to be the solid 2 bladed fan ratting at the joint. However if you don't have the mechanical type fan , then maybe check the timing chain tension ?
Regards Steve
Regards Steve
- Concrete-crusher
Thanks.
No mechanical fan so that?s out.
Hope it?s not timing chain because the head was re-worked just a few months ago. Also, it?s intermittent so that would rule the the timing chain out?
Best
Best
1967 S3 SE DHC
Doesn't sound like the timing chain to me. Especially from the video/sound taken from the top.
Besides dip-stick, how about alternator/generator bracket/mounting?
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
I also had the mounting plate on a high torque starter become loose and rattle.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
Thanks all. I?ll check dipstick, Dynamo and belt, and starter tomorrow.
Any more suggestions, folks. I do like the idea of it being a loose ancillary.
My darkest fear is water pump, but presumably that?s more of a silent killer?
Best
Best
1967 S3 SE DHC
.......my engine also sounds "sluggy" at idle and cold HOWEVER if we could of heard the same engine hot and at idle it'd be easier to make a diagnosis!! sandy ------------------------- goin ta bed! PS my engine starts imediatelly and after a mile of slugginess everythings' back in the green! lets hear her at various stages of WORK (high revs hot, leaving home early in the morning, getting layed back in 1hr hr of traffic and still 90? C water temp. whereafter some of us'll may detect the problem. sandy: just a mediocre TC scientist!
- el-saturn
Thanks Sandy
Confirm the video was taken with hot engine, after a 45 minute drive.
Best
Best
1967 S3 SE DHC
Check the clutch release bearing / fork. Does the sound change with pressure on the clutch pedal?. Also check noise with clutch disengaged and car in gear, clutch engaged transmission in neutral to see if there is any difference.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
A new timing chain can ease off and rattle at tickover - tends to disappear if revved up a bit.
Not a big problem to sort just take out slack until noise goes.
Could be chatter on release bearing which would probably go with pressure - possibly even manually under car if single handed.
- MarkDa
Stevie
Do I hear an exhaust leak?
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
RESOLVED!
The two bolts that secure the exhaust to the bracket on the gearbox had parted company with the rest of the car. So at idle the exhaust was knocking against the bottom / side of the gear box.
An easy fix
Thanks all for your help. Love this forum.
Best
An easy fix
Best
1967 S3 SE DHC
