Alternator Adjustment Strap - source?
• Page 1 of 4 • 1, 2, 3, 4
The strap on my Sprint has broken and I would like to obtain a direct replacement - can anyone guide me to a supply source, please?
(see foto of broken item)
BTW, I have bought a strap from Paul Matty but it is quite different (with a 'fork' at the engine-end) and isn't at all suitable, as the 'fork' is way too wide. Other suppliers on the net illustrate the same item, unfortunately!
mmatthej1 - Second Gear
If my memory is right. It should be mounted to the middle bolt hole not the top. (You also need to rotate 180 degrees)
I believe there were some issues with your original type damaging the timing cover hence the addition strengthening plate and modified adjuster.
- mbell
It looks like the correct bracket and correct orientation to me. Her's a photo in case it helps.
Dougal.
Dougal.
- dougal9887
Thanks to all - I will take the 'fork' bracket out to the car & try the suggestions shortly!
As far as the piccie is concerned (for which big thanks), I see that the strap is on the INSIDE of the alternator bracket, whereas my broken one sat on the outside - that must be just as good and opens up a different positioning for me to try!
WRT the strengthening strip, where would this fit in?
Hum - still struggling !
I've again offered up the fork strap to the engine - it HAS to fit to the bolthole arrowed on my picture, doesn't it?
...... but if that is the correct bolthole, I still see the big gap, as per second picture !
Am I missing something !?!
I found the above picture from the WS manual useful. this may also help you work out what you have....
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
More thanks, for latest info/pictures - I now begin to understand where the reinforcing strap goes (It seems to be called a 'Mounting Strap'; I don't have one but will see if Paul Matty or someone else has one, as it looks helpful !)
It rather looks that my car had the 'simple' strap used when a dynamo is fitted, whereas the one used for an alternator is of the 'fork' type, per the other picture.
(seems a bit odd that a stronger strap is used for the lighter-in-weight alternator !)
- Attachments
- image6-red.jpg (80.81 KiB) Viewed 1274 times
Phil, The bracket you made is perfect. Any plans to make more? Dan
