engine block numbers
PostPost by: mgfollett » Fri Feb 10, 2017 6:54 pm
Hi, Can anyone tell me what 4 cylinder block cast numbers (2737E6015B) would be from and is it suitable to use for twincam block?
Thanks, Mike
mgfollett
First Gear
First Gear
PostPost by: promotor » Fri Feb 10, 2017 8:19 pm
Mk1 Transit and Mk2 Cortina - it's a 1600 block that uses a 77.62mm stroke crank.
Can be used for a Twincam but you either need specific pistons (tall block pistons) or deck the block by 5.75mm if using with standard Lotus pistons and the 2737e con rods.
promotor
PostPost by: StressCraxx » Sat Feb 11, 2017 4:06 am
mgfollett wrote:Hi, Can anyone tell me what 4 cylinder block cast numbers (2737E6015B) would be from and is it suitable to use for twincam block?
Thanks, Mike
The Dave Bean Elan catalog has a page (and the parts) to perform the conversion without decking the block. PM me your email and I can forward the scanned pages.
Dan
StressCraxx
