ZETEC HELP PLEASE
PostPost by: Bill » Mon Feb 06, 2017 1:41 am
I have a silver top Zetec from a 1995 Ford Contour - I am looking for advise on determining displacement / horsepower.for same.
There is a computer bar code label on the front black plastic timing chain cover with the # 54G-776-BA - 05/12/95 printed on it.
I got this with a partially restored Spyder framed '72 S4 Federal Sprint coupe that I purchased from David Seville - Peck before he died here on Vancouver Island. Zetec's are not an off the shelf item here by any means and I wish to get on with the rebuild this coming winter but I want to confirm what I have first.
Best sources for conversion parts? Any help will be appreciated.
Bill
Bill Rathlef
Vancouver Island, Canada
Bill
PostPost by: prezoom » Mon Feb 06, 2017 4:39 am
Bill,,
I am nearing completion of the installation of a 2L silver to Zetec in my Plus 2. I just ordered to Weber 152G carbs, those configured with the 5 progression holes. I am told that with these carbs, one can expect between 160 and 170 horsepower, without adding alternate cam shafts, but constructing a tubular exhaust.
I have done all the work to adapt the engine to a 2000E transmission, and along with Bud English have figured out the flywheel/driven disc/clutch cover/ annular throwout to make things work. All of these parts, incuding a carb friendly intake manifold are readily available on line.
Bud has been a wealth of knowledge when it comes to installing a Zetec, though, his is a blacktop. The engine mounts shown in the Mods section by C42 work like a charm. I can supply a bunch of photos of what I have done to make this mod work, and can forward via email.
If you have any questions, do not hesitate to contact me. Can be reached at: [email protected] or, h760 741 3514. If you call and I don't answer, leave a message.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: Bud English » Mon Feb 06, 2017 5:17 pm
I don't know about that whole "wealth of knowledge thing, but what has helped us both is the sharing of ideas back and forth. It is a different project than it is for someone in the UK with multiple local sources for parts at hand, up to and including specialists the will do the whole swap.
The internet is your friend and there's not a lot of difference between dropping a zetec into an Anglia and into your car other than the tightness of the fit. Like Rob, any info I can provide, I'm glad to do.
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: c42 » Mon Feb 06, 2017 8:31 pm
Maybe as browse through this website may help.
http://www.turbosport.co.uk/forumdisplay.php?f=143
Good luck
c42
PostPost by: autopia » Sat Feb 11, 2017 9:30 pm
Bill,
I think one of the easiest indications is the capacity cast into the block, on my silvertop, there's a '20' on the right hand side under the inlet manifold, I've also see 18 on a 1.8 blacktop, so they seem to be consistent on UK engines.
It'll be next week before I can get down to my workshop but I could take a pic of the cast number in the side of the block when I do.
best regards
autopia
First Gear
First Gear
PostPost by: autopia » Sat Feb 11, 2017 9:36 pm
Bill,
I just looked at one of the pages on the link provided by c42 (John) and you can see the engine displacement casting number in one of them:
http://www.turbosport.co.uk/showthread. ... cdfac8b4d6
I thought mine said 20 but it looks like it should be 2.0
Also, with DHLA40's, a big bore exhaust and an ECU (only firing the spark plugs), I believe it is supposed to put out around 145-150bhp. It does have re-profiled cams which might've taken it a little higher but I need to rebuild it first to try it.
best regards
autopia
First Gear
First Gear
Users browsing this forum: richardl46 and 12 guests
cron
