Leaking at Y Piece
I am getting exhaust leaks from the Y piece junctions probably due to the fact that the new SS manifold ends were not exactly parallel to each other. I would like to try and avoid removing the manifold from the car as it's such a pig of a job. Are there any other options? Is it worth removing the main pipe and Y piece and reassembling with some form of exhaust sealant? Worst case, if I had to remove the manifolds I guess one of the pipe ends would need a saw cut, bend and reweld? Any suggestions?
- William2
Remove the Y piece and main pipe, give everything a good clean with a wire brush / emery cloth whatever, then use lots of exhaust assembly paste http://www.halfords.com/workshop-tools/ ... regum-150g
providing you are not trying to fill holes or repair rusted or weak components there's nothing wrong with using this stuff. It works well and will seal effectively.
Crack on, get that car on the ramps
Kindest regards
Alan Thomas
Alan Thomas
I had a leak at the y, did as Alan suggested and it was sorted.
I'd be a little careful how much you use. I've just pulled mine apart to find a two pebble sized chunks of paste in there. One was attached one was lose. Shouldn't cause any real problems but probably explains the exhaust rattle I'd sometimes hear. Didn't think I'd used that much paste either.
- mbell
Users browsing this forum: Elanman68, pharriso, RAJ2628 and 26 guests
