poly v pulleys for twin cam
I occasionally see photo's of elan twinks with poly v belt pulleys for water pump/alternator and crank pulley -yet I cant find any suppliers. does anyone know where to purchase high quality items of this type??
- mike in grimston
Mike,
Can't help you with the poly v belt drive. I have fitted a toothed belt drive (Gilmer drive) kit from Burton Power in the UK. I run the belt quite loose, and the side load on the water pump is minimal. The kit includes three pulleys and the belt.
http://www.burtonpower.com/water-pump-p ... p225k.html
Colin.
Colin.
mike in grimston wrote:I occasionally see photo's of elan twinks with poly v belt pulleys for water pump/alternator and crank pulley -yet I cant find any suppliers. does anyone know where to purchase high quality items of this type??
'68 S4 DHC
- fatboyoz
Ah Mr Gale,
Well spotted.
This is the actual item I have: FP225DK. Doesn't actually say it is for the TC, but fits and has been fine for the past 6 years.
http://www.burtonpower.com/water-pump-a ... 225dk.html
http://www.burtonpower.com/parts-by-cat ... s.html?p=5
This kit is for an alternator shaft size of 15mm. There is also a kit for 17mm alt' shaft size.
Colin.
Well spotted.
Colin.
Mr.Gale wrote:The kit from Burton Power looks interesting but it look like it only connects the crank to the water pump, what about the alternator?
Mr.Gale
'68 S4 DHC
- fatboyoz
fatboyoz wrote:This is the actual item I have: FP225DK. Doesn't actually say it is for the TC, but fits and has been fine for the past 6 years.
Colin.
As shown above the x-flow kit works with a Twin Cam. So going with that is it possible that this poly v kit that also is for an x-flow would work with a Twin Cam?
http://www.burtonpower.com/poly-v-kit-water-pump-alternator-drive-x-flow-711m-fp315k.html
As a slight aside has anyone come across this front end drive arrangement before or is it most likely a home brew of parts?
Simon
SimonH - Third Gear
Although it is not on their website Paul Matty do a kit. 3 pulleys and the belt. Talk to Sam.
- mike in grimston
Europatc wrote:Welcome Mike, which Grimston are you in?
Not Yorkshire, but Norfolk!
- mike in grimston
sure I got mine from qed nice kit but as engine not run yet I can only assume should the job do very well curly
- curly type 26
