knock knock.....
hi all
driving home yesterday started getting a bit of a knock from the engine.......
got home and tried the long screwdriver stethoscope which seemed to point to front of cylinder head...
doesn't sound like timing chain, but I could be [hopefully] wrong.....I suppose it could be any of a number of things ....cam bearing? cam follower? valve spring?...
whn it stops raining I will be removing cam cover to inspect.......any hints on what to look for?
I would be grateful for any pointers!!!
thanks in advance..
fred .
thanks in advance..
fred .
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
hi rohan
thanks for your reply
it is a fairly high frequency.....
have looked at the cams/valve gear and all seems ok.... clearances are a bit more than book but all exhaust and inlet similar
play of timing chain about 1/2in between cam sprockets, but I have a question on that .....
the cam sprockets are relatively fixed with the pressure of the valve springs on the lobes so even with a load of slack around the rest of the chain would there be much more play between the cam sprockets?
I am beginning to suspect tensioner sprocket.........do they wear out often?. is it possible to remove the pivot pin and tension sprocket assembly without taking the head off?
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Yes it is. Set to No1 TDC with cam timing marks aligned, slacken tensioner, undo cam sprockets and remove. Slacken tensioner pin, grasp the tensioner with long nosed pliers, remove the tensioner pin and remove tensioner sprocket assembly.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
I haven't changed my idler sprocket in 270,000 miles and I can't see why it would induce a knock. I assume you have tightened the chain since the knock started as they do stretch over time, allowing the cams to clatter. I tighten until it starts whining and then back off a little as I find the up/down measurement is too vague to rely on.
Meg
Not sure what you are hearing, but if it's a rather hard knock that gets worse with speed, it could be a rod bearing. If you pull the plug wire from that cyl and the knock stops that would indicate that it probably is a rod bearing.
- webbslinger
well, could it be something as simple as adjusting/tightening tensioner?
yes it could!
thanks for all the replies!
btw valve clearances were around 0.027 [ex] and 0.017 [inl] ..
I appreciate this is well over book settings, but won't do any harm apart from a bit down on power, and a bit rattly when cold....
is it worth re-shimming to correct clearances, or leave it for a winter job? [I use the car every week]
yes it could!
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
hi rohan
as posted above I adjusted tensioner and knock has gone.......
I will probably replace timing chain and adjust valve clearances over the winter....I can at the same time check if tensioner sprocket/bolt/bearing needs replacing......
what's your opinion on split link timing chain [not racing!!]
thanks for your help!
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
I have used a split link chain for a number of years in a racing engine I did not want to pull down so I don't see any real problem in using one in a road engine. Not my preference but it is not an unacceptable real world compromise
Just make sure the chain itself is a good quality solid roller chain and that the removable link clip has its open end facing backwards from the direction of chain travel.
The adjuster sprocket does wear and bend so they run at an angle to the chain so they do need replacing.
Hi Fred
I agree with Rohan, just fitted a new split link chain to stop clatter of a stretched chain.
A new solid chain will be fitted next time the front cover comes off, hope that's not to soon.
Make sure you attach a good strong cord for the pull through.
Good luck
Good luck
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Fred,
I think you've been using metric feeler gauges measuring in 0.01 mm steps to get 0.027 and 0.017 gaps. In inches these would be 0.0106" and 0.0067", on the money. If they really were 0.001" measurements it would sound like a diesel and you wouldn't have noticed the knocking!
Meg
