Oil pickup pipe press fit
Hi Guys,
I'm wondering whether anyone has had issues with the press fit used on later pickup pipes becoming loose. In my younger days scouring wreckers yards when English Fords were everywhere I well remember taking the sump off a newly reconditioned crossflow engine I was going to purchase only to find the crankshaft and it's bearings totally destroyed. On closer examination I found the oil pickup pipe to be loose at the press fit interface between the pipe and the block. It was obvious that the oil pump had been sucking in air at this point rather than oil from the sump!
I don't want the same thing to happen to my Lotus engine and as it is currently the press fit seems to be a bit loose. Do you guys have any recommendations regarding how to restore/improve the press fit or a suitable sealant to use at this joint? The pickup is the big wing type so unfortunately I cannot easily find a replacement because the Elan/Cortina type is different.
Photos of the pickup and of the press fit section are attached for reference.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Consider getting it swaged to a tighter-fitting diameter.
'67 S3 SE FHC
'67 S3 SE FHC
I always use Loctite bearing fit, never had a problem but also its not loose in the block.
Also mine is a straight tube.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
rgh0 wrote:The bent tube is for a rear bowl sump engine such as used on Escorts
I'm puzzled because such an engine will presumably not fit in a Lotus, yet the original Poster said his problem is for a Lotus engine.
2cams70 wrote:Hi Guys,
And the few I have noticed are straight
RDENT
The swinging one was bent. From a recent post. Maybe that one has to be.
I suppose on long sweeping corners the baffles do their thing (CeeJay design). And the largest accusump does not have enough in reserve. I suppose its all a moot point as things have been this way for 50 years. So outside of a dry sump...
Maybe I am missing something. I am hoping to be ready to make baffles and secure a “swagged” oil pick up tube with 641 “loctite bearing” i think it was.
Sort of surprised there is no stainless safety wire or the like...
Love your Mother
Earth
Love your Mother
Earth
The original post from some time ago was by 2cams70 and he has a couple of twincam escorts with the rear bowl sump and hence the bent pick up compared to the straight press in one in the Elan. If you modify the sump for the swinging baffle design up then you need to modify the pickup tube to add a bend to bring it to the centre of the sump if using the press in style block
Users browsing this forum: No registered users and 45 guests
