Camshaft Sprockets
A silly question to most, but is there any difference between the sprockets, i.e.. one for inlet, one for exhaust?
have got some second hand sprockets that appears the same, teeth and marking are all the same.
Cheers Neal
Cheers Neal
IF EVERYTHING SEEMS TO BE GOING WELL, YOU HAVE OBVIOUSLY OVERLOOKED
SOMETHING.
SOMETHING.
- Apx
The exhaust timing mark is advanced one tooth compared to the inlet. The jackshaft sprocket is physically the same, but no timing mark.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Sorry all,
Going through the books I've just found a reference that the exhaust side will have "ex" scribed on it. Althought exceedingly faint i have now found it on one... Now to sort the cam shafts out. Thanks for your replies i am re etching the sprocket for future reference.
Neal
Neal
SOMETHING.
SOMETHING.
- Apx
Apx wrote:A silly question to most, but is there any difference between the sprockets, i.e.. one for inlet, one for exhaust?
Cheers Neal
In my 40 years of T/C building, I have bought quite a few pairs of cams and gears, nearly all new. The cams have always been matched pairs. The sprockets have invariably had a line cut to mark the timing position, with two markings, 'IN' on one side, and 'EX' on the other. I grind off the unrequired marking to distinguish the fitted inlet and exhaust cams. I have always had to use offset dowels to get the timing exactly to the cam specifications.
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
