Fuel pump blanking plate.
PostPost by: dougal9887 » Fri Mar 25, 2016 8:53 pm
Having installed an electric fuel pump, I've fitted a plain blanking plate to the mechanical pump aperture.
Now I'm wondering if a baffle on the back of the plate is desirable/essential?
Dougal.
dougal9887
PostPost by: john.p.clegg » Fri Mar 25, 2016 10:49 pm
Nope,as long as it stops the oil coming out of the hole....
John :wink:
PostPost by: TroonSprint » Sat Mar 26, 2016 9:05 am
Just a plain flat plate on mine. Doesn't seem to be a problem.
TroonSprint
PostPost by: dougal9887 » Sat Mar 26, 2016 9:25 am
Ok. Thanks for the reassurance.
I had just noticed the Burton offering complete with baffle. I assume this deflects oil splash towards the breather from the jackshaft.
Dougal.
dougal9887
PostPost by: 2cams70 » Sat Mar 26, 2016 9:35 am
Hi Dougal,
I'm assuming you mean the blanking plate with baffle available through Burton's and pictured below. I bought one for my engine on the basis that there is no harm in it being there and it's only a small extra cost. I think however that it's more critical on the pushrod OHV engine than the Twin Cam. When a catch tank elbow connector is fitted in lieu of the standard oil separator can on the pushrod engine there is nothing between it and the spinning camshaft below so the baffle should greatly assist in preventing oil being fed to the catch tank in this circumstance. The twin cam has the drain tube between the head and block in this position so probably not so critical.
Paul
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: dougal9887 » Sat Mar 26, 2016 10:26 am
That makes sense, thanks for the info.
Dougal.
dougal9887
PostPost by: Mick6186 » Sat Mar 26, 2016 12:09 pm
If you are fitting a thin steel plate & no plastic spacer you will need to shorten the bolts.
Mick.
Mick6186
PostPost by: dougal9887 » Sat Mar 26, 2016 2:58 pm
I just re-used the existing bolts as they didn't appear to foul. Quarter inch plate but no spacer.
Dougal.
dougal9887
