Sump Pan - Car Type?
PostPost by: William2 » Fri Nov 06, 2015 11:38 am
I am trying to get hold of a sump pan for my twin cam. I have been advised that they were fitted to Mk2 711M block Cortinas as well??
William2
PostPost by: Lyn7 » Sat Nov 07, 2015 9:03 am
Hi William, I believe you are correct. What you need is a sump from a "6 bolt" crank engine with a front bowl. It does not need to be 711M. Escort bowls were to the rear because of the suspension cross member. I think they are now quite difficult to get , good luck.
Lyn7
PostPost by: nmauduit » Sat Nov 07, 2015 11:26 am
there are some excellent posts on sumps on the forum, see for exemple :
lotus-twincam-f39/lotus-oil-pan-same-pinto-t28539.html
S4SE 36/8198
