Jackshaft locating dowel
I've bought a replacement jackshaft and the locating dowel is not long enough to pass through both the spacer and the jackshaft sprocket. Is it necessary that the jackshaft sprocket has to locate on the dowel, or are the two bolts sufficient?
thanks in advance
thanks in advance
JHE007 - New-tral
The dowel is a crucial part of the jackshaft and should be used. Although not as important as making sure camshafts have a dowel fitted (due to load differences when considering valve spring pressures) there is still a fair amount of load imparted on the sprocket due to the driving of the oil pump. For the price of a dowel it is much better to have one fitted to keep peace of mind.
promotor - Fourth Gear
