Question - Compressed head gasket thickness
Does anyone know the thickness of a compressed (used) headgasket? I'm measuring valve to piston clearance and my old headgasket didn't survive teardown. I don't want to compress the new gasket until I assemble the engine for real. Or am I simply being cheap and should I use a gasket for this measure, then another for assembly?
Thanks in advance
Thanks in advance
- Jentwistle3
I've just measured the head gasket that came out of my engine recently. Firering, average of 16 measurements, 4 per combustion chamber, is 0.73mm, range 0.71 to 0.75mm
Hope that helps
Malcolm
Hope that helps
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
I used .60 mm to allow for the fact that the gasket will have sprung back slightly.
Dougal.
Dougal.
- dougal9887
