Mixed Camshafts
PostPost by: RogerFrench » Mon Jun 08, 2015 3:29 am
Any informed opinions, please, on the likely performance of a Big Valve engine, Stromberg, with QED360 inlet cam and Std Sprint exhaust?
RogerFrench
PostPost by: rgh0 » Mon Jun 08, 2015 4:34 am
My understanding is the QED 360 is essentially the same grind as the sprint cam so it should be the same as having 2 sprint cams.
PostPost by: RogerFrench » Mon Jun 08, 2015 3:50 pm
rgh0 wrote:My understanding is the QED 360 is essentially the same grind as the sprint cam so it should be the same as having 2 sprint cams.
Which is more-or-less what I hoped, thanks Rohan. I'm endeavouring to transform a US-Federal low-compression emission-controlled engine into something like a UK-spec S4.
So I have removed the emission controls, changed inlet and exhaust manifolds, new vacuum-less distributor. Next is to take 40 thou' off the head and fit new camshafts. Or maybe high-compression pistons and camshafts, not sure yet.
By the way, this is all happening to a Europa TC, but this board is much more knowledgeable!
RogerFrench
Users browsing this forum: No registered users and 44 guests
