Catch tank / can
At present the breather at the rear of the cylinder head vents via a pipe to the floor around the gearbox. Hardly clean, either for my rear end nor the road/track.
Can I vent via a catch can to the Stromberg back plate when the air filter is a Pipercross, ie foam front section?
I assume there is something to be gained by doing this as far as engine back pressures go? ( road engine)
If there's no benefit to the engine then I'm tempted to vent the output hose back to ground, hopefully with less discharge.
Any thoughts?
Graeme
Any thoughts?
Graeme
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Long discussion about breathers and catch cans in this topic:
lotus-twincam-f39/head-gaskets-and-oil-breathing-t31678.html?hilit=breather
In short.
The early Elans had a drip pipe from the breather hole, which dripped its waste oil on the road. The later Elans had a pipe with a wire filter in it, going from the breather hole near the back of the head to a short projecting pipe on the air box just to the rear of the rear trumpet.
Many owners have fitted catch tanks instead in various places.
In short.
Thanks Bill.
There's some good stuff there. The question still remains about the suitability of plumbing into a foam air filter but it sounds like there were more concerns about a flash back of fuel down to the head, than my perceived concern about oil soiling the inside of the air filter.
A small catch can and some stainless stell wool and the necessary plumbing seems to be in order.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Users browsing this forum: GLB and 39 guests
