Oil return pipe
I exchanged the oil return pipe with a new rubber item from one of the usual suppliers. However, there is still a leak dripping down on the starter and then the floor, so I will go back to the old metal pipe with new o-rings. As you can see from the tilt in the picture, one of the surfaces is not perpendicular to the head or the block and it seems to me that this will cause a leak, although it looks like the pipe manufactured this way.... Are the surfaces on the block and head not parallel?
/Ulf
/Ulf
1974 Lotus Elan +2 130/5
- Uboat
That is a home made tube, the head and the block are parallel with each other so have no idea why someone made it like that did you rotate the rubber tube when you had it in place? they sometime dont locate too well and rotating usually seats it.
Have you checked it is not the petrol pump that is leaking oil from its mounting?
Users browsing this forum: GLB and 36 guests
