Brake pressure increases rpm
Hi when I was having the Mot test last week , we got to the part where you hold down the brakes. I noticed this caused the rpm to increase by about another 300 rpm
Can anybody tell me if this is normal , or is it a symptom of an vacume leak or something
Elan s3 with webers
Thanks in advance.
Elan s3 with webers
Thanks in advance.
- Concrete-crusher
not normal on mine....
could be pedals interfering...?
oversize shoes...?
ok not helpful, I know.....
fred
oversize shoes...?
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
Hi thanks ,it's a replacement servo bought new from Christopher Neil about 15 years ago , the cars done about 300 miles since then as it's been stood up , so I'm not surprised if something is sticking.
I was pressing the pedel hard
Is it something that will cure , or is it likely to get worse ?
- Concrete-crusher
Thanks , one last question , is it a user serviceable part , I ask because I tried servicing the original servo with the service kit , and it never worked again , hence the replacement all those years ago.
- Concrete-crusher
You could try these people for a kit although I have no experience with them.
http://www.powertrackbrakes.co.uk/brakes.html
Hello Steve, I have used Powertrack over the past 3 years for all my brake parts. Their service is first class and so far they have always had the parts in stock. I don't recommend people or services readily but they are first rate. Im just a very satisfied customer and nothing more
all the best
Stuart
all the best
Stuart
Europatc - Third Gear
The air valve controls the amount of air that is let into the pressure side of the chamber.
When there is a positive pressure differential on the fluid side it lets air in and a negative pressure differential it opens to the Vaccum side and sucks air out - When the fluid pressure is at equilibrium both sides of the valve are closed - this is how it applies pressure in proportion to the pedal effort.
Try using it - It may improve.
Do the revs increase at lighter pedal pressures? Is the servo providing any assistance?
- AHM
"could be pedals interfering...? "
Maybe the shaft is a little tight and pressing the brake moves the accelerator ??
