Weber big valve head
The short answer is anything between ?0 and ?4000, depending on condition. If it is mint, new rebuild (or new) flat and well within thickness tolerance, complete with perfect valves / seats / buckets / bearings and good cams then it's towards the top end.......especially with an invoice for professional rebuild by a known expert. If it's at or below the thickness tolerance, cracked, waterways rotted, warped, then towards the bottom end.
Something that has a good thickness, no cracks, no waterway oxidisation and is flat, but needs valves / valve seats / guides / buckets and cam bearings would probably go for around ?1500 I would guess. You can work it up or down from there depending on condition!
