Tudor Recuperator Bottle, restore or replace?
PostPost by: pharriso » Fri Mar 27, 2015 9:55 pm
My car ('72 Federal Sprint) came without a Tudor Recuperator bottle, but did have the bracket. I was fortunate enough to source a bottle from Randall Fehr.
Question. The bottle is very discolo(u)red. Is there a way to clean it up without losing the original Tudor decals? Bleach, alcohol?
TudorBottle_Bottom.JPG and
base of original Tudor Recuperator bottle
I bought a replacement bottle from Paul Matty, but it's really not that good a match; For a start the replacement bottle is not a good fit in the new bracket ( I could solve with foam packing) & the bottle is a different style to the original:
OldnNewTudorBottles.JPG and
Orginal vs. Matty bottle
NewBottle_Bracket.JPG and
Matty Bottle & Bracket
The new bottle fits the old bracket quite well. BTW it's made by Technical Treatments in Sevenoaks Kent, nothing to do with Tudor.
Now onto the old / brackets. Some of the welds have failed on my old bracket, I can have it rewelded or brazed.
The new bracket is a completely different shape to the old! The new style looks like it should be screwed to a bulkhead. Whereas my old one has a couple of extra holes in the base & bolts to the tray in front of the radiator. The old bracket is not square in any direction! Is mine poorly made, or is it supposed to be like this?
OldnNewBrackets.JPG and
Old & New Brackets, bottom of old bracket is angled
OldTudorBracket_AngledTop.JPG and
Circle at top is at angle to vertical posts!
So at the moment I am favoring restoring the old bracket (sand blast, reweld then paint black), if I can clean up the old bottle (I'd like to) I'd reuse that, otherwise I'll use the new bottle with a Tudor decal.
Comments?
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: trw99 » Fri Mar 27, 2015 10:22 pm
Phil. As you know, I'd always go for using the original. Your plan for the bracket seems sound.
For the bottle you firstly need to do all you can to retain the Tudor brand mark. Try cleaning the inside with a couple of Steradent tablets. See how that goes. If successful, fill a bowl of water and treat the outside the same way. If the dirt/opaqueness remains, try Miltons Baby Bath liquid soap.
These are not aggressive cleaners but should help make the bottle look a little smarter.
PostPost by: Elanintheforest » Fri Mar 27, 2015 11:25 pm
I came across this article a while back and tucked it away for future reference. Perhaps you can be our guinea pig Phil!
De-Yellowing Plastics
We've all had plastics that have yellowed and won't wash clean. Sometimes it's just a pale gray mouse or keyboard slowly going beige; sometimes it looks like a severe "nicotine staining" and we assume there must be a smoker in that household (I've known nonsmokers to overestimate the satanic evils of smoking, since smokers rarely "lit up" in their homes, yet the stains were all over the house, and quite dark.) A white plastic chassis may turn such a dark brown in hot spots that you may be certain it must be burning, and may even discard it. The staining can often spell the difference between a treasured collector's item or conversation piece and worthless junk. It's not uncommon for perfectly functioning household items to be replaced because they are dingy and ugly: organizers with once-clear plastic drawers, lawn furniture, kitchen appliances... anything visitors might see.
Many of you may have suspected it wasn't environmental, but rather "aging". I've had items that yellowed while sealed in plastic inside never-opened factory original boxes, and identical plastics exposed to identical conditions may differ greatly in yellowing: Most of us have seen two-toned chassis where the top and bottom were dramatically different colors after as little as a year. Game consoles, computers and other electronics devices that get warm are particularly prone to this.
It turns out this yellowing is usually the result of bromine released from flame retardants added in the master batch to facilitate production and later molding. (Bromine, you will recall is a dark reddish brown liquid at room temperature) The loss of bromine doesn't necessarily mean that the plastic itself is deteriorated or unable to give decades of further performance, though a mental illusion often convinces us they feel brittle or rough.
It turns out to be relatively easy to remove these stains with common household materials. You may be surprised how "factory new" some items feel after deyellowing. More than once, I've been surprised, because I'd come to believe an item had been beige to start with, but the cleaning (and internal surfaces) reveal that it was originally white or gray.
ESSENTIAL CONCEPTS
I'm not going to get too deep into the chemistry (which actually dips into quantum mechanics), but I want to make it clear what we are *not* doing. Though the key chemicals are often used as bleaches and cleaners, the process is not bleaching the plastic or removing dirt. It's just mobilizing the bromine, which has migrated to the surface, and forms a stable complex with atmospheric oxygen. (Note that the bromine didn't stain the full thickness of plastic upon manufacture.)
The second key point is that ultraviolet light is CRITICAL to the process. The UV is what actually mobilizes the bromine -- just as heat and UV often contribute strongly to plastic yellowing, but mobilizing the bromine to the surface in the first place. If you use the solution alone, you may not get appreciable effect from soaking plastics for weeks in you basement. Since you only need a day or so of direct sun (or the equivalent in UV lamp or indirect shaded sun), you won't damage the plastic
Stronger is *not* necessarily better. We're really trying to *limit* the reaction, so ther eaction only reacts with the UV-activated bromine (the easy target) reacts, not the plastic. The plastic is much more resistant, but there's thousands or millions of times as much plastic as bromine present.
Daylight UV isn't a problems --these plastics are designed to stand up to sunlight for much more than a day-- but too-strong UV lamps, too much heat (the rate of the undesired side reactions doubles with every 10C rise in temperature), high peroxide concentrations, too much activator (creating too many free radicals), too long an exposure (after most of the bromine but gone) or letting the cleaner completely dry -- all of these may slightly overclean or even damage the surface. I'd suggest keeping the peroxide under 20% or more: 6% (20 volume) works fairly well (and you don't really need gloves) and even 12% is still pretty mild (and is unlikely to react dangerously with many of the incompatible substances on the MSDS warning). Then, if you see just a wee bit more stain that you want to knock off, try a brief UV session (maybe 30 minutes) at high peroxide concentration.
I originally encountered this idea in a blog entry by someone who restored *deeply* yellowed (actually brown) old game consoles and computers by soaking the cases in big plastic trays full of hydrogen peroxide (and a few other chemicals) on their back porch. I was impressed by the results, but it seemed expensive (and rather a hassle) to fill those big containers with chemicals, especially here in New England, where the weather might not cooperate. Who wants to bring big, heavy, sloshy trays of strong chemicals out of the rain, and store them inside the house?
However, the process seems to work equally well if you mix a smaller batch, add a thickener, and simply brush it on. If one activating chemical is lect out of the mixture, it can be stored for weeks, to be activated and brushed on as needed. The objects can be left out if it starts to rain, and rebrushed when the sun comes out. It's easier than painting.
THE RECIPE
a. 500 ml (1 pt) Hydrogen Peroxide(H2O2) diluted to 6-12% (20-40 volumes)
While 3% (10-volume) drugstore peroxide can work, it may take many days of UV exposure. Further, since it is borderline to start with, it may not last very long: you may need a new batch each day. Finally, since hydrogen peroxide breaks down to oxygen and water, the stuff in your bathroom (or store) may be substantially less than the stated 3%. ("10 Volume" means that 1 volume of solution will release 10 volumes of oxygen gas. You could easily jury-rig a measurement test, using, say, a dab of manganese dioxide paste from inside a dead dry-cell or alkaline battery as a catalyst)
For quicker, and likely better, results, use a stronger hydrogen peroxide. I'm personally happy with 6-12%, but some go up to the strongest that is easily obtainable e.g. probably Prochem Urine Rescue, available at many custodial or carpet cleaning suppliers (~$20/gal) or pet supply retailers (Petco, Petsmart) for ~$30/gal. It's about 30-32% or "100 volume". Beauty supply shops (like Sally Beauty in the US/Mex/EUR/JAP) sell hair bleaching peroxide up to at least 40 volume (12%) for a few bucks a pint, but you should examine the ingredients. Avoid any with Terpene (which can eat plastic) and generally avoid organic compounds (crudely: anything whose name doesn't trace to ammonia or the periodic table) with one exception: Tetra Acetyl Ethylene Diamine (see below). If it comes premixed in the peroxide (vs. in a separate packet), your deyellowing solution won't last as long in storage.
To dilute peroxide: initial concentration * initial volume = final concentration * final volume
e.g. 30% * 1L = 6% * 5L, so add 4L water to 1L 30% peroxide solution to get 5L 6% peroxide
Though home use peroxides of over 6% should come with warnings enough, I feel obligated to say:
WARNING: Read the MSDS. Hydrogen peroxide is a strong oxidizer and corrosive to skin, eyes, lungs (if inhaled directly), clothing and wood products. It may react violently with some substances, including acids, bases, metals, metal salts, reducing agents, organic compounds, flammable substances. ONLY USE CLEAN GLASS OR PLASTIC CONTAINERS AND UTENSILS AND PROPER SAFETY GEAR (e.g. gloves and goggles). A dab of the black paste found inside a dead flashlight battery, dispersed in some water, will catalyze hydrogen peroxide to oxygen and water for disposal. Add it carefully/sparingly to avoid splatter/boilover of unreacted peroxide.
b 2.5-5cc (1/2-1 tsp) Oxy-Clean powder (activator)
This contains a small amount of Tetra Acetyl Ethylene Diamine (TAED) which acts as a catalyst for the hydrogen peroxide in our deyellowing solution. Oxy-clean also has perborates and perchlorates (which is what the TAED is *meant* to catalize) These may add a little something to the deyellowing process, but I never bothered to compare it with pure TAED.
c Food Thickener (optional, only use for paste form)
I suggest food thickeners beause they are cheap, available, and shouldn't contain any incompatible contaminants that react with peroxide. I suggest making a roux, slurry or cooking the thickener to paste, as you would with food, before adding peroxide. NEVER heat anything containing hydrogen peroxide on your stove. Make a thick goo, cool, then mix it with the peroxide. I use a magnetic stirrer to avoid putting metal in contact with peroxide, but many report using hand or kitchen blenders to mix the peroxide paste, over months of experiments, so I guess steel, especially stainless, must be okay. I definitely wouldn't even think about an aluminum blade or pan.
Arrowroot, flour, cornstarch, potato starch, xanthan gum, CMC/carboxymethylcellulose, guar gum or food thickeners sold to help older people swallow all work, and are available in grocery or health food stores. I use Xanthan gum, because I bought a big bag for food experiments, but found it a bit slimy for my tastes. A few mil of glycerine really helps Xanthan thicken up.
Proper use
You can dilute the peroxide and mix with thickener weeks in advance. Always store peroxide and its mixtures in a cool dark place in a glass or plastic container, but not on a wood shelf or on paper liner. It may slowly decompose to water and oxygen, especially if the container isn't scrupulously clean. Don't cap it so tightly that it will burst from internal pressure if you forget it.
Set up a place to "sun" the plastic object all day. You can hang it from strongs over a plastic tray to expose all sides, or just lay it down yellow side up. If possible, arrange a loose transparent cover to prevent drying. Make sure pets, children, stupid friends, etc., can't get at it. The reaction will work, but more slowly, in a shaded location with good exposure to clear sky, or on a lightly cloudy day. You may prefer shade in hot climates in summer: the modest heat of the reaction added to the heat of direct summer sun could dry the paste or warp some plastic parts
You can set it up indoors with a UV lamp, but place the lamp at least 18" (50cm) from the tray, so the heat from the lamp doesn't add to the heat from the reaction.
Resist the temptation to deyellow intact electronics. I know some of you will do it anyway, once you've had some practice, but don't say I didn't warn you. (Trained mockers are standing by!) Instead, remove the chassis as much as possible, put sandwich bags over any remaining exposed metal, Remove any logos, stickers or decals (especially aluminum sheet decals or aluminum shielding paint inside some electronic devices, both of which can get quite eaten up and cause splotchiness) -- a heat gun or hair dryer will help you peel them off intact with a sharp razor blade. If you prefer, seal them in situwith wax, hot glue, or even tape (but tape isn't always reliable for this)
Just before use, dissolve the small amount of Oxy-clean in some water then mix that into your goo. Brush it liberally into the yellowed surfaces. You may choose to wrap the piece in clear plastic kitchen wrap to reduce evaporation: drying concentrates the ingredients and can cause splotchiness.
If you've done everything properly, the brushed-on paste should quickly foam a bit under the UV.
I'd try to check in on the progress every few hours, until you get a feel for the strength of you personal recipe. In my experience, a 6-12% peroxide mix should nearly or completely deyellow a chassis in 3-8 hours with no damage if the piece is left from dawn to dusk.
A TRIAL OF TOTAL IMPROVISATION
After a few tries, it becomes very easy. In fact, the reason I wrote this up was because I did a totally slap-dash job this morning that came out fine. I needed to de-yellow the diffuser (cover) of a large fluorescent lamp for a project, but we've only had maybe half a dozen fully sunny days in he last two months. As I was headed out the door, I remembered this would be one of those days, but I didn't have time to mix a batch, find a big enough tray, etc., so this is what I did:
Reasoning that the translucent diffuser would be fairly transparent to UV, and was also not nearly as badly yellowed as an opaque object of similar ugliness, I sprinkled a pinch of oxyclean in a large sheet of plastic wrap, placed the diffuser on top, then sprinkled another pinch of oxyclean. I then folded the saran wrap around the diffuser, put it in a shallow cardboard tray to keep the ends from unfolding, and carried it to the sunniest part of my deck, where I carefully opened one end, and poured in some ordinary 3% peroxide (probably much weaker -- it was old).
In spite of taking so many liberties, each of which weakened the deyellowing effect, the job was mostly done when I got home. Had I not been using old 3%, I would have rinsed it off, to avoid undesired non-UV peroxide reactions that might slowly make the plastic brittle, but since the "3%" was probably more like1-2% to start with, and is probably much less now, I just left it out for tomorrow, to do what it can with the morning sun, if I stagger home in the wee hours tonight.
PostPost by: Spyder fan » Sat Mar 28, 2015 8:32 am
Or buy a new one and retire your original to the garage shelf http://www.ebay.co.uk/itm/CLASSIC-CAR-T ... 3cb9fef9cb
Kindest regards
Alan Thomas
Spyder fan
PostPost by: gjz30075 » Sat Mar 28, 2015 8:45 am
Phil, have you tried a plastic polish?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: nebogipfel » Sat Mar 28, 2015 10:20 am
I'm probably barking up the wrong kettle of fish but isn't the washer bottle smaller than the recuperator?
nebogipfel
PostPost by: pharriso » Sat Mar 28, 2015 10:43 am
nebogipfel wrote:I'm probably barking up the wrong kettle of fish but isn't the washer bottle smaller than the recuperator?
Yes, I know there are at least two sizes. I will enquire though.
For the record the recuperator bottle is 3 3/4" OD x 7.5" to the shoulder.
Phil Harrison
PostPost by: pharriso » Sat Mar 28, 2015 10:54 am
Thank heavens for the internet & Google...
According to http://www.oldtimerbedarf.de/ GWW918K is Total height 170 mm, width 95 mm holder, Diameter 75 mm (3"), so smaller. :(
I can't imagine Matty not carrying the correct Tudor bottle if it were readily available. :roll:
Phil Harrison
PostPost by: Spyder fan » Sat Mar 28, 2015 12:08 pm
Large ones available here, but no Tudor logo, the stickers are available that say Tudor, but it seems a bit of a compromise and not quite right especially at the relatively high price versus the smaller version.
http://www.holden.co.uk/displayproduct. ... de=040.022
Kindest regards
Alan Thomas
Spyder fan
PostPost by: elanner » Sat Mar 28, 2015 12:58 pm
Phil,
Restore the old one!
I think this is one of those cases where a new one will simply look weird. And certainly not original. "The original fell apart so I had to fit this new one."
Of course, I'm assuming that you're looking for: "this is the original and it's in great condition for being over 40 years old." As opposed to "it's 40 years old and totally knackered." ;-)
So I guess it all comes down to whatever effect that you're trying to achieve! Driver or trailer queen. Or both. ;-)
Nick
PS: Be careful cleaning it, the Tudor lettering comes off far too easily.
PostPost by: pharriso » Sat Mar 28, 2015 1:04 pm
gjz30075 wrote:Phil, have you tried a plastic polish?
Greg, what cleaner would you suggest? Not sure what Plastic polish is...
Phil Harrison
PostPost by: gjz30075 » Sun Mar 29, 2015 9:27 am
Something like this. Obtained at any auto parts store or at Wal...
They're typically for clear plastics, like headlights, but worth a try.
MEG-G-12310_xl.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Elan45 » Mon Mar 30, 2015 3:20 am
During the restoration of my pre-airflow FHC, I've had my recoup bottle soaking and last week I removed the bottle bracket from the floor of the nose. The remnants of original paint is a medium blue, probably "Tudor" blue as shown on the above replacement bottle.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: richardcox_lotus » Mon Mar 30, 2015 11:29 am
Ah yes Roger, but what are you soaking the bottle in ??
'72 Sprint
