Pink chunk in cooling system
PostPost by: mariodschy » Tue Mar 10, 2015 2:25 pm
The gasket of the thermostat housing was leaking so i changed it, when i dismanteled the thermostate i found pink chunk in the system (see the pictures). The cooling system was filled with pink cooling fluid so the chunk comes frome this, the question is why there were these nuggets.
Maybe someone has seen these befor and know the reason for this, it doesn't look like that it was mixed with another cooling fluid but i am not 100 percent sure what the former owner did.
IMG_5456.JPG and
IMG_5442.JPG and
- 1972 Lotus Elan Sprint LHD/DHC
- 1962 Austin Healey Sprite MK II - Sold 09.05.2016
Sorry for my bad survival English ;-)
mariodschy
PostPost by: gjz30075 » Tue Mar 10, 2015 2:35 pm
Maybe someone poured in some radiator stopleak?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: draenog » Tue Mar 10, 2015 3:06 pm
Has somebody inadvertently mixed traditional blue antifreeze with modern OAT red antifreeze? The two don't mix and the organic acids cause precipitation of the silicate, turning the coolant to sludge...
Rob.
draenog
PostPost by: theelanman » Tue Mar 10, 2015 3:39 pm
draenog wrote:Has somebody inadvertently mixed traditional blue antifreeze with modern OAT red antifreeze? The two don't mix and the organic acids cause precipitation of the silicate, turning the coolant to sludge...
Rob.
youd hope not but certainly looks that way.....
urgh.....that's gonna take some cleaning.....
hope there was enough fluid to keep the engine cool......
theelanman
PostPost by: john.p.clegg » Tue Mar 10, 2015 4:09 pm
Nothing that half an hour with the hosepipe won't cure..
John :wink:
PostPost by: pharriso » Tue Mar 10, 2015 4:43 pm
john.p.clegg wrote:Nothing that half an hour with the hosepipe won't cure..
John :wink:
What about the heater matrix etc?... :(
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: john.p.clegg » Tue Mar 10, 2015 5:31 pm
OK then,make it an hour...
John :wink:
PostPost by: mariodschy » Tue Mar 10, 2015 6:49 pm
gjz30075 wrote:Maybe someone poured in some radiator stopleak?
Thats a good question maybe this is the reason, i don't think that it was mixed with blue cooling fluid because when i drained the system it was all pretty pink.
The radiator is not in best shape i'll change them, when i washed the radiator there were no pink nugetts to see.
I've washed the engine twice from waterpumpe side and from thermostat side also by turing it on the head (engine is out of chassis, oil is drained) using hot water and compresed air
mariodschy
PostPost by: pharriso » Tue Mar 10, 2015 7:00 pm
Don't forget the heater lines & the heater as well...
Phil Harrison
PostPost by: mariodschy » Tue Mar 10, 2015 7:03 pm
pharriso wrote:Don't forget the heater lines & the heater as well...
Good idea this i'll do next, the heating valve were also full of this shit...
mariodschy
PostPost by: john.p.clegg » Tue Mar 10, 2015 7:59 pm
I've seen clear/white jelly like deposits formed on the thermostat housing when left for a while...maybe these with pink colour picked up from the anti-freeze......any chemists in the house...Aluminium and water with what other chemical?
John :wink:
PostPost by: elansprint71 » Tue Mar 10, 2015 11:35 pm
Can't wait for the Aussies to comment- where is Barry McKenzie when you need him?
Someone clearly chundered a raw prawn into the coolant.
Has this forum gone a bit too serious... again? :twisted:
I'll report this post and see if anyone is in control.
