Pin Bolt tensioner Arm Bracket - ALUMINIUM washer
PostPost by: SJ Lambert » Thu Mar 05, 2015 2:01 am
I've been to all the hydraulic and motor shops around town to source a replacement aluminium washer - only one that I can get my hands on has both ID & OD that's too small - does anyone have a correct size supply?
P1100497ac.jpg and
Elfin Monocoque (Twin Cam)
[email protected]
SJ Lambert
PostPost by: john.p.clegg » Thu Mar 05, 2015 8:07 am
What's wrong with a copper washer?
John :wink:
PostPost by: promotor » Thu Mar 05, 2015 9:02 am
I always use a "dowty washer" on the tensioner pivot bolt and the tensioner nut to timing case - maybe searching for those will bring up a whole load of further options.
http://www.ebay.co.uk/itm/Assorted-Box- ... 3f22e9b6b7
promotor
PostPost by: SJ Lambert » Thu Mar 05, 2015 11:50 am
john.p.clegg wrote:What's wrong with a copper washer?
John :wink:
Not much, it'd be nice to use an aluminium one like first time around. Copper ones are easier to get!
[email protected]
SJ Lambert
PostPost by: Barty » Thu Mar 05, 2015 12:01 pm
I had a similar problem recently on a banjo fitting on suspension of my merc. I was able to stretch the aluminium washer by putting a socket extension, which had a nice flare, through washer and bashed extension with a hammer. It 'coned' it slightly but flattened out once torqued into position.
Barty
First Gear
First Gear
PostPost by: RichardHawkins » Thu Mar 05, 2015 7:00 pm
SJ,
I also use a bonded washer (Dowty) they are a combination of zinc plated steel, for strength, that gives you something to tighten up to and compliant rubber to create a seal. When installed you can only see the zinc plate colour which is very similar to aluminium in appearance. Most hydraulic companies stock them.
Richard Hawkins
RichardHawkins
