Replacing Dipstick Tube
PostPost by: William2 » Fri Feb 20, 2015 5:28 pm
Is it possible to fit a new dipstick tube into the block with the engine assembled on the bench without too much trouble?
William2
PostPost by: AHM » Fri Feb 20, 2015 6:02 pm
Yes!
Warm the casting locally with a blow lamp.
Grip the tube with Mole Grips
Pull and twist.
To replace with a new tube (you've just destroyed the old one!
Lubricate the tube.
Using a drift with a shoulder that fits the tube (or a long bolt that is a good fit) Tap the tube into place.
Check the depth of the tube to set the correct Fill reading - There is a whole discussion about this.
AHM
