Nylon generator mounts
PostPost by: vstibbard » Mon Nov 24, 2014 11:43 am
Does anyone know of a manufacturer of nylon generator mounts, they are used to isolate some of the vibrations in race engines
Alternatively can anyone recommend material to machine one locally?
Regards V
PostPost by: bigvalvehead » Mon Nov 24, 2014 2:58 pm
Hi Vaughan
TTR does them check his website.
Did you get my last mail?
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
bigvalvehead
PostPost by: vstibbard » Tue Nov 25, 2014 12:29 am
HI Dave, thanks I'll check .
Yes I did, I've been monitoring EBAY and in discussions with trailer manufacturer, the numbers are not stacking up.
A friend has referred me to company that he regularly uses to ship cars and parts for a quote to box and ship the car in dedicated container, with view to getting it away pre Xmas as I understood you're back early December, is that still the case?
V
PostPost by: 7skypilot » Sun Nov 30, 2014 11:38 am
Wilcox Engineering do a metalastic bushed bracket and a nylon adjustment strap that I've used on BD's with success. I guess the Kent derivative blocks are very similar to our twin-cams. However, as with a TT nylon bracket a strap will be needed to earth the alternator to the block
Worth a call, maybe.
7skypilot
PostPost by: vstibbard » Fri Dec 12, 2014 10:11 pm
Thanks I will drop an email to Wilcox.
Cheers V
PostPost by: patrics » Sat Dec 13, 2014 11:59 pm
Hi you should try Luke motorsport (wosp) for the nylon bracket
patrics
Users browsing this forum: No registered users and 46 guests
