Cam cover
PostPost by: john.p.clegg » Wed Nov 12, 2014 5:08 pm
Cedric asked for some info,here is the cam cover
2014_1213cancover0001.JPG and
I use Stainless nylocks
2014_1213cancover0003.JPG and
over stainless washers
2014_1213cancover0004.JPG and
over fibre washers
2014_1213cancover0005.JPG and
and use silicon to make a semi-permenant gasket
2014_1213cancover0006.JPG and
note the silicon hose bits fitted to the cam cover studs
2014_1213cancover0007.JPG and
and the anti-splash plate..
2014_1213cancover0008.JPG and
and removed
2014_1213cancover0009.JPG and
a little bit filed away to help prise the cover off
2014_1213cancover0010.JPG and
just a bit of Ali drilled and shaped
2014_1213cancover0011.JPG and
John :wink:
PostPost by: Pistacchio sprint 72 » Wed Nov 12, 2014 5:23 pm
Fantastic thanks! :mrgreen:
Cooled down by CliveyBoy!
PostPost by: Pistacchio sprint 72 » Wed Nov 12, 2014 5:26 pm
So the silicone tubing put around the screws help to prevent the oil to leak out...? Good idea then
PostPost by: pharriso » Wed Nov 12, 2014 6:49 pm
Ray at RD Enterprises is selling a cam cover gasket made from modern materials;
New Uprated TC Cam Cover Gasket
New composite fiber gasket with silicone sealing bead
This is the most durable gasket yet! Attach the plain side of the gasket to either the head or the cam cover with sealant, the integrated silicone bead will seal the other side.
Ref. 26E0001HP $22.00 each
Quantity pricing: two @ $20.00 each, four @ $18.70 each
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: RichardHawkins » Wed Nov 12, 2014 8:35 pm
Phil,
Do you, or anyone, know if these gaskets are available in the UK?
Richard Hawkins
RichardHawkins
PostPost by: pharriso » Wed Nov 12, 2014 9:14 pm
No idea... I know they are made in Italy though so you'd think....
Phil Harrison
PostPost by: Pistacchio sprint 72 » Thu Nov 13, 2014 8:28 am
Darn I live close to Italy, I even dropped my Twincam monday overthere for a refresh...
Phil you need to find out who make them!!!!
PostPost by: Grizzly » Thu Nov 13, 2014 11:36 am
RichardHawkins wrote:Phil,
Richard Hawkins
I had a Cam cover gasket Identical to that i bought from Burton a bit back, It was expensive i seem to remember (4 times the price of a Cork one) and its not reusable just like the cork.
The annoying thing is i only had it on a year before i had to remove the cam cover (can't remember why) so i went back to Cork. Thing is i've never had any oil leak issues with any of my Cam Cover Gaskets?? The cork i only use once, Buy them in a sheet so they don't deform, fit it dry and make sure the two surfaces are thoroughly clean / degrease. You can tell if you have done it right if the next time you have to remove the Cam cover its stuck down so takes effort to remove.
PostPost by: pharriso » Thu Nov 13, 2014 6:44 pm
I was told the RDent one is re-usable...
Phil Harrison
PostPost by: Maulden7 » Fri Nov 14, 2014 9:39 am
Cometic gasket - reusable & does not need sealant, but it is advisable imo to apply some over the "D" inserts.
http://www.burtonpower.com/cometic-cam- ... 19com.html
Available from a number of sources in the UK - circa ?20.
Maulden7
Users browsing this forum: tonyabacus and 50 guests
