Twincam engine weight please?
Hello,
Could someone tell me the weight of a Twink without carb nor fluids nor alternator?
I need to ask a quote to a transporter...
Thx
Thx
Cooled down by CliveyBoy!
Pistacchio sprint 72 - Fourth Gear
I just shipped a twin cam long block and it was 175 lbs.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
And I weighed a head some time ago at about 19Kg, so with a fair amount of maths..
175 lbs + 19Kg +10% = 79Kg + 19 kg + 10% = approx 108 Kg
That seems a bit high to me, no doubt someone will come along with a better figure.
Do yo not have a person-weighing bathroom scale you can measure it on?
I assumed that "long block" was a block with sump, crank and rods and pistons and head and cam and front cover fitted. No flywheel or clutch or ancillaries like alternator, fuel pump, oil pump or carbs?
A "short block" I believed was like the above but with no head fitted
But I guess terminology may vary from place to place.
Rohan, your definition of a long block is 100% accurate.
Glen
I think 175 is on the light side when comparing weights that might be listed for other engines.
this old list:
http://www.gomog.com/allmorgan/engineweights.html
lists the pushrod kent as 260, and I doubt it weighs less than the twink[twice as much aluminum as the iron head etc]
frequently those weights include some ancillaries
this old list:
- gus
My notes show a kent 1600 block w/o flywheel or head at 168 lb. twink head asm 45 lb, cam cover 4.5 lb. Elan block would be close, more alum at front but slightly shorter block. Measured by myself with bathroom or fish scale so close but not dead accurate.
Orig. starter 10 lb, generator 12 lb ( some gen. are a bit lighter).
I weighed most things as I removed and replaced in case I wanted to add lightness someday, or just for curiosity...
Jack
Jack
- jk952
260 lbs with dynamo, flywheel & carbs.
thank you all.
I needed the weight to ask a quote to a transporter. But I might transport it myself...
why not look at ferry prices if you are going to collect from u.k. and make a long w/e to keep swmbo happy also
- alan.barker
Just got confirmation from my engine shop that the total weight of the shipped twin cam long block was 200 lbs.
Glen
I need to lift it and put it in the trunk of my family mover....
Did you lift it by hand into the car or did you use a crane?
Users browsing this forum: No registered users and 50 guests
