711M block
The engine serial number on my recent Elan purchase is 711M6015BA. Although I'm disappointed the car doesn't have the original engine, I seem to remember the 711 block is a desired commodity. The car runs like a bat out of hell. Is there a good reference for information on this block? My car is a '66 SE with Weber carbs.
Chris Herr
Chris Herr
67 Elan Super Safety
67 Elan +2
67 Elan +2
- seniorchristo
Hi Chris
The 711M block is the later 1600 "tall block". Never originally fitted to the Elan which always used the various versions of the 1500 "short block" from Ford over the years ( 116E,120E,681F, 701M, plus a few with the numbers ground off for some reason). The later Elans used the 701M block which was the 1500 equivalent of the 711M.
Depending on how exactly the engine has been built you will have the longer stroke crank and larger capacity as a result. You will also have a spacer at the top of the front cover or a new tall front cover to accommodate the taller block.
While all the Ford 1500 / 1600 blocks had a number of detail differences in the castings they are all essentially interchangeable (with more or less work). The big advantage of the later 701M / 711M blocks is they came with much stronger square main bearing caps which saves you from doing the line bore to fit these caps (or steel caps) to the earlier blocks
Thanks Rohan,
I guess i'll never know what's inside until I open it up and see . It looks like the engine leaks oil from everywhere so that may be sooner than later. Compression is 180 on all (4) cylinders. There was initial blue smoke when first starting after it had sat idle for about 6 weeks but it mostly went away after driving for a bit. Is this typical or an indication of worn valve guides? I can't say enough how appreciative I am of the help you and others offer to board memebers.
Later
Later
67 Elan +2
67 Elan +2
- seniorchristo
I just went out side to check and sure enough it has the spacer between head and front cover. Now I'm really psyched to see what's inside. I know there is a windage tray in the oil pan from some previous service records.
Later
Later
67 Elan +2
67 Elan +2
- seniorchristo
Moderator
Sorry I meant to enter this thread in the engine forum
67 Elan +2
67 Elan +2
- seniorchristo
Blue smoke on start up or after idling for a while that's goes away as you drive is fairly typical of worn valve guides. Blue smoke that gets worse as you drive is fairly typical of worn oil control rings and / or bores. But no hard and fast rules and you always really need to look inside and measure to really know whats going on.
Chris, 711M6015BA is your engine's block designation and not your engine number. For a 1966 Elan your engine number will be in the LP5###,6### or 7### series.
Have a look to see if such a number is visible on the block, intake side mount, horizontal surface.
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
If you decide to switch to the shorter block, save the crank, flywheel, pan, real seal carrier (and probably a few other bits I can't think of now) to transfer to the shorter block for a stroker build. There will be debate as to which rods to use, 125E or 2737, and pistons will need to custom but you'll have a screamer for sure with a more original look.
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Thanks for all the info. I now know the 711 numbers are not serial numbers. The motor runs great. It has good compression (180 psi in all 4 cyls.). It seems much quicker than I remember my S4 being but that was 40 years ago. Other than some blue smoke at start up after sitting a while and some oil leaks, I have no reason to change anything.
I am wondering if the reason the car sits up higher in the front is to allow clearance for the tall block between engine and bonnet. The car is a 1966 S3.
Later
Later
67 Elan +2
67 Elan +2
- seniorchristo
The stance has nothing to do with the engine to bonnet clearance. There was a big discussion on front springs recently and because its an S4, the taller springs helps the headlight height requirement, or something like that.
Engine to bonnet clearance is fixed and not much can be done about it, except some fancy motor mounts to lower the engine but there's very little room for variations from factory.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
Yes of course. It has nothing to do with the clearance. Thanks giz
67 Elan +2
67 Elan +2
- seniorchristo
See:
http://www.lotuselan.net/wiki/Lotus_Twi ... ild_Part_1
and
http://www.lotuselan.net/wiki/Lotus_Twi ... ild_Part_2
and especially
http://www.lotuselan.net/wiki/Torquing_ ... am_Rebuild
and
and especially
With 180ps on all 4 cylinders, I don't think I would be pulling the motor anytime soon. You maybe could just wash the engine down and address the oil leaks. You may be able to reduce the amount the engine leaks.
Just drive it and enjoy,
James
James
holywood3645 - Fourth Gear
gjz30075 wrote:Engine to bonnet clearance is fixed and not much can be done about it, except some fancy motor mounts to lower the engine but there's very little room for variations from factory.
The PO could very well have shimmed the body shell up off of the frame to create clearance between the top of the engine and the bonnet.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Users browsing this forum: No registered users and 45 guests
