timing query
PostPost by: RichC » Sat Jul 26, 2014 4:26 pm
everything runs fine. over last 5 years I've never had pinking , even when i've not bothered with additives . Bear in mind I've a stock pre-unleaded head used to running on 4star! So maybe you can forgive my thoughts that timing might be a little retarded...so i thought i'd check .....
According to the book, standard cam early +2 with Webers is 14deg btdc at 2500rpm.
I have ~ 19deg btdc at 2500, ~10deg btdc at idle.
I'd be happy to have anyone's interpretation and comments/.observations pls.
Rich
RichC
PostPost by: alan » Sat Jul 26, 2014 7:19 pm
if it's running fine, leave it and just drive :mrgreen:
Alan.B
alan
PostPost by: KevJ+2 » Sat Jul 26, 2014 7:25 pm
Rich,
What distributor / ignition (electronic?) are you running and how old are they?
Kev.
KevJ+2
PostPost by: RichC » Sat Jul 26, 2014 10:04 pm
standard +2 orig spec distributor by looks of it
RichC
PostPost by: rgh0 » Sun Jul 27, 2014 12:05 am
Reading the workshop manual with regards ignition timing is a problem as it has a few errors.
The 2500rpm quoted in the manual as crankshaft rpm is actually distributor rpm but the 14 degrees is actually crankshaft degrees as quoted. The 14 degrees is centrifugal advance and needs to have the static advance of around 10 -12 degrees added.
This gives you maximum advance of 24 to 26 crank degrees at engine 5000 rpm
The 19 degrees you measured at 2500 engine rpm is about right and well within the tolerances on the measurment and distributor.
PostPost by: RichC » Sun Jul 27, 2014 6:43 am
That's grand !. Thank you Rohan, so as i thought , the timing is a little retarded & I have a little room to play with in terms of advancing the timing up to 24deg btdc.
thanks a million
Rich
RichC
PostPost by: RichC » Sun Jul 27, 2014 6:46 am
...at 5000 rpm !
RichC
PostPost by: RichC » Sun Jul 27, 2014 6:48 am
so maybe 19deg btdc is right on the money at 2500 rpm ! I'll leave it as it is then lol !
RichC
