Fly Wheel Question
PostPost by: AlfaLofa » Fri Jul 25, 2014 6:54 pm
I have an engine with a 6 bolt crank which has no fly wheel.
The crank is drilled for just a single fly wheel dowel.
Which of the 2 following offerings would you advise?
The Burton wheel appears to use no dowels whereas the QED fly wheel uses 2.
http://www.burtonpower.com/parts-by-fit ... fl254.html
or
http://qedmotorsport.co.uk/qed-shop/lot ... d/6bdd/12b
Excluding the drilling - why do they look so different??
Also am I right in assuming that the standard clutch size is indeed 8.5 inches?
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa
PostPost by: rgh0 » Sat Jul 26, 2014 12:26 am
The photos are different because they are looking at opposite sites of the flywheel.
The cranks had a single dowel hole in them but I dont believe Lotus used a dowel in the 6 bolt cranks. All the orignal Lotus 6 bolt flywheels I have dont have a dowel hole.
The Burton flywheel appears to be lightened, the QED flywheel appears to be "standard pattern" which I presume means not lightened
A standard flywheel with ring gear is around 7.0kg
A typical lightened steel flywheel with ring gear around 5.5 kg
A typical Aluminium flywheel with steel facing and ring gear around 3.5kg
Extreme racing flywheels with just a rim and spokes can be under this weight
I dont understand why Burton quote a different weight for the flywheel with inertia ring gear versus preengage ring gear
The Elan orginally used an 8 inch / 200 disc I beleive in a 8.5 inch / 215 mm pressure plate assembly. The later Plus 2 had a 215mm clutch plate and you can (and most have?) retrofit Elans with the 8.5 inch clutch plate.
PostPost by: AlfaLofa » Mon Jul 28, 2014 7:37 am
Thanks again Rohan !!
AlfaLofa
Users browsing this forum: 2cams70 and 29 guests
