Dry Sump (Hart) suggestion: please comment!
PostPost by: el-saturn » Sat Mar 29, 2014 2:00 pm
g'day! here's two sketches (two versions of same setup) of how i figure my new (not really) pump should get hooked up: may I assume that all of these (titan, pace, cosworth etc..) are the same and if not can you tell me
where I'm wrong?!?! .................. maybe i'll be chasing the easter rabbit in a couple of weeks (that's the plan).
thanks for any assistance sandy 36/4982
elanPUMP2.jpg and
elanPUMP1.jpg and
PostPost by: arcangel » Sat Mar 29, 2014 8:29 pm
A bit difficult ot visualize from your sketch but the flowpath looks correct. The Burton power catalog has a flowpath showing the correct layout for a typical dry sump system.
I'm currently in the process of dry sumping a Cosworth YBB motor in a Lotus Europa. The oil pump shown is similar to your Brian Hart with one extra scavenge stage. I do not plan on adding an oil cooler at this time but the flowpath is similar to yours. The top right of the photo shows an adaptor for a remote oil filter. I'm not however too clear on where the hose from the pump outlet from the oil tank goes to for the remote oil filter.
Copy of dry sump pump 002.jpg and
arcangel
First Gear
First Gear
PostPost by: gav » Sat Mar 29, 2014 8:50 pm
The diagram that I used for my dry sump pump is the same as your bottom drawing.
Mine has an expanded description on the out to oil cooler side in that it states Out to dry sump tank top via coil cooler.
Hope it helps
Good luck
Gavin
gav
PostPost by: gav » Sat Mar 29, 2014 8:51 pm
Thats supposed to be oil cooler not coil cooler !
Oops
gav
PostPost by: holywood3645 » Sun Mar 30, 2014 1:13 am
This is from my BDG, it has a Hart dry sump system. It is the cosworth instructions for dry sump installation on BD engine.
Hope it helps.
Email me if you have any issues with picture
James
dry sump oil system BDG.JPG and
PostPost by: gav » Sun Mar 30, 2014 7:35 am
James
What are you running the BDG in?
Gavin
gav
PostPost by: el-saturn » Sun Mar 30, 2014 7:56 am
thanks fellas! especially for the drawing AND, most importantly: I?m right and everything has been prepared accordingly. i?ll be showing the next steps (head is finished) and parts: my xmas, birthday, fathersday, nameday etc... presents: instead of .......................... let?s say jewellery for ze wife!
enjoy the awfully (75db) sounding malaysian GP - in 10min. sandy j
PostPost by: holywood3645 » Sun Mar 30, 2014 10:25 am
The Blue and White TIMEX MK1 (my latest project)
James
blue abd white.jpg and
PostPost by: gav » Sun Mar 30, 2014 12:24 pm
James
That looks fun....
gav
