Twin cam Block height same as 1100&1300cc Xflow & BDH/J ,
I have 2 blocks one is an 'L' and the other is from a 'BD' (BDJ/BDH) with 81mm bores with steel main caps new 81 mm liners installed. etc.
I just measured the BD block and compareed to the L block. They are both the same height. 20cm or 7 7/8" (I always though the small cc kent blocks 1100/1300cc were shorter)
My head is now working overtime now. I'm thinking of building a BD (somthing) using the BD block 1600cc crank, steel twincam rods or 1600 height rods (I dont have rods yet). Im wondering if anyone has played with a BD with this setup. I know some of you have speadsheets to caculate the cc. Open to ideas
I have a nice ported BD head, twin 40's cam carrier etc, It would be a cheap build for me.
Thoughts???
James
Thoughts???
James
holywood3645 - Fourth Gear
I was hopeing you would jump in. I always thought so as well. I went look for info and could not verify.
These 2 blocks are same height. I will look for numbers on the one with 81mm bore and steel caps. I thought it was a BDH/J block
James
James
Pic's
Not much in the way of numbers. It looks like some heve been ground off.
I see
'LP' on corner at one end and a small B50
LP6503-LBA above one engine mount
6B19
James
I see
6B19
James
holywood3645 wrote:I have 2 blocks one is an 'L' and the other is from a 'BD' (BDJ/BDH) with 81mm bores with steel main caps new 81 mm liners installed. etc.
Thoughts???
James
Hello James,
You might contact Ken Anderson. He could tell you all you need to know. He used to work for Cosworth.
Dan
What I though was a BDJ/H block appear to be a Lotus block (explains the height) Same question applies however. Has anyone built a BD motor using a Twin cam block? I have a steel cosworth crank 1600cc and could use twin cam of 1600cc rod height,
James
James
When I was looking at options for my engine I came across this.
I can't remember were I found it, but it seems correct.
It might be of use to some members to work out a plan.
Jon the Chief
Jon the Chief
- Attachments
- Ford block deck heights.pdf
- (53.7 KiB) Downloaded 1175 times
- oldchieft
