Accuspark glitch
PostPost by: robertverhey » Mon Feb 03, 2014 6:26 am
Finally got around to fitting my Accuspark electronic ignition. Nice piece of kit but appears to have a major design flaw, ie the rev limiting rotor fouls on it as per pic below. Has anyone else encountered this, and if so, found a remedy? If it comes to a choice I'll have a rev limiter and points any day......and I'll be letting Accuspark and their local outlet know!
Any advice welcomed
image.jpg and
robertverhey
PostPost by: miked » Mon Feb 03, 2014 8:22 am
Robert, their rev limiter box is only about 30 quid and works well. I would sooner run that than rely on an HT cut out. My opinion so don't stone me. Mike
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: oldchieft » Mon Feb 03, 2014 9:22 am
If you buy the Stealth black box from them for 100 pounds you get the electronic kit for 20.
Jon the Chief
oldchieft
PostPost by: Keith Scarfe » Mon Feb 03, 2014 9:44 am
Yep I have exactly the same issue when I fitted mine not so long ago. I had to ditch the rev limiting rotor arm and put in a standard one. Luckily I had one lying around from an old crossflow dissy.
I should look into something electronic as a rev limiter really, currently have nothing. Do you have a link to some info on the Accuspark one mentioned above.
Keith Scarfe
PostPost by: robertverhey » Mon Feb 03, 2014 10:16 am
Thanks for replies, have had a look on eBay and I can get an accuspark rev limiter for the price that mike mentioned. Looks like it was a false economy buying a cheaper accuspark instead of the more expensive pertronix (which I know doesn't foul, been running one on my other twink for ages) I'll probably ditch this one and get a pertronix, would prefer to keep the rev limiter as ACBC intended.
So I have an unused accuspark for sale, if anyone interested, PM me!
Robert
robertverhey
PostPost by: oldchieft » Mon Feb 03, 2014 12:00 pm
oldchieft
PostPost by: robertverhey » Mon Feb 03, 2014 12:11 pm
Thanks Jon, all things considered will just keep the mod basic, ie replacing the points with "fit and forget" ignition
robertverhey
PostPost by: Galwaylotus » Mon Feb 03, 2014 3:46 pm
robertverhey wrote:I'll probably ditch this one and get a pertronix, would prefer to keep the rev limiter as ACBC intended.
I didn't know he intended to install electronic ignition!! :?
'67 S3 SE FHC
Galwaylotus
PostPost by: Hawksfield » Mon Feb 03, 2014 8:01 pm
Ditched my rev limiter years ago
they were never very reliable to cut out at a safe rpm, I rely on the rev counter
An electronic limiter is a better idea even with points if it is possible.
+2s130 1971
PostPost by: oldchieft » Mon Feb 03, 2014 9:34 pm
Rev limiters of old were horrid, when you hit it it would cut dead then fire up at full power and cut again.
If you were careless you could break something in the drive line.
Around the 70's soft cut rev limiters came in and just cut every forth spark, then every other spark if the revs kept rising.
I fitted an early one from micro dynamics with points and it was very smooth and safe.
IMG_0830.jpg and
rev limit and electronic ing.
It also had a switch that would immobilise in the mid position or bypass the electronics and rev limiter in an get you home mode.
later I replaced the points with a Lucas AB13 Hall effect pointless set up. so I had electronics driving electronics.
It seems a bit silly but it kept the rev limiter and did away with the points.
Of late the rev limiter stopped working and would only work in EMG mode. So I have the black box from Accuspark and a spare distributor ready to fit when I finish the present round of work.
But yes you can have useful rev limiters on points systems.
Jon the Chief
oldchieft
cron
