Adjusting Titan Oil Pump
PostPost by: anglotype » Mon Dec 23, 2013 7:11 pm
Hello Guys,
I equipped my Twin Cam with a Dry Sump System. The Oil Pump is a Titan. Now i have to adjust
the oil pressure. Can anybody tells me; is there a ground adjustement for the first run on the adjustment screw.
If i turn the engine with the starter, the pression is going up to 10lbs (o.k. Engine cold, Oil cold 20W50, outside Temp. 3 Degree)
What are your recommendations?
Sincerely anglotype
anglotype
New-tral
Users browsing this forum: No registered users and 50 guests
