Crankshaft pulley and oil leaking
PostPost by: CG901 » Wed Dec 18, 2013 5:08 pm
I have searched the workshop manual but don't see an illustration of how the crankshaft pulley impacts the oil seal. I had a new aluminum crankshaft pulley made but not anodized. I am being told the anodizing is absolutely necessary to eliminate the wear on the pulley v-surface which can wear quickly and cause undue noise from the belt, also lack of anodizing will cause problems with the oil seal.
Anybody have experience with this? Thanks - Scott
Current: 1965 S1.5 26/4004, 1966 S3 FHC 36/5192, 1958 Fiat Abarth 750GT Zagato, 1967 Brabham BT21B, 1988 Arrows A10B-04, 1991 Brun C91-001.
Past: 1971 Elan S4/SE DHC, 1972 Europa Special, 1980 Esprit Turbo, 1988 March 881-05, 1990 Leyton House CG90105
CG901
PostPost by: 45bvtc » Wed Dec 18, 2013 6:05 pm
Cast iron Scott, cast iron: NO Cheshunt and/or Wymondam factory twin-cam engine left the factory with an aluminium crankshaft pulley and I do wonder why that was?
45bvtc
PostPost by: RichardHawkins » Wed Dec 18, 2013 7:00 pm
Scott,
I have no experience of aluminium crankshaft pulleys. However, as a student I think I remember my metallurgy lecturer telling us that anodising had three purposes.
To enhance corrosion resistance.
To create an attractive finish (usually coloured anodising)
To produce a hard wear resisting surface.
Like most things it will be more complicated than my what I can remember. There are many different grades of aluminium all of them designed for a particular purpose.
In short I expect the advice about having it anodised is correct, but you probably need to research the grade of aluminium you need.
Richard Hawkins
RichardHawkins
PostPost by: CG901 » Wed Dec 18, 2013 9:27 pm
Thanks to Richard, et al. Anybody see why the type of metal on the pulley may negatively affect the oil seal?
CG901
PostPost by: Chancer » Wed Dec 18, 2013 9:35 pm
2 possibilitys.
The surface finish of the turned aluminium pulley is unlikely to be as fine as specified by the seal manufacturers and will probably wear the seal, the standard pulleys are surface ground in this area which unless things have changed cannot be done to aluminium, in any case it will just go into a CNC machine as a block of alu and come out a turned pulley.
The hardness of the material may not be sufficient without anodising to resist being worn down by the seal, even hardened steel shafts have worn ridges from seals in use.
Chancer
PostPost by: robertverhey » Wed Dec 18, 2013 9:55 pm
Third possibility....a speedi-sleeve where the seal runs
http://www.skf.com/au/products/seals/in ... index.html
robertverhey
PostPost by: alan » Fri Dec 27, 2013 1:59 pm
with the pulley hard anodized, i think the seal dia can be polished
Alan.B
alan
