Spark plug gets dark
PostPost by: Pistacchio sprint 72 » Mon Dec 09, 2013 7:56 am
Hello,
Saturday was rally day. I woke up at 6, jumped in the car and drove to pick up my copilot.
The engine was badly sounding. Like on 3 cylinders.
I opened the bonnet and sprayed waters on the exhaust headers to find the faulty cylinder.
Found out number 2. I checked the wire connectivity by using a new plug and i could see the spark.
So decided to remove the spark plug number 2.
It was black and did not spark anymore.
Put the new one instead and drove like i stole it to the rally meeting point.
2 days after the new spark plug number 2 is getting dark. So the mixture is too rich.
Is it that screw i need to close slightly? Thanks
image.jpg and
Cooled down by CliveyBoy!
PostPost by: john.p.clegg » Mon Dec 09, 2013 8:50 am
If only it was as easy as that,you need to determine at what throttle position you are running rich,Gunson Colour tune might help or a rolling road.
John :wink:
P.S.
Could also be on the high tension side (rotor,dissy cap,plug lead,plug) that is at fault.
PostPost by: twincamman » Mon Dec 09, 2013 10:15 am
Not the brass one the one above it 1. 1/4 turn out at 2000 rpm when the motor is hot.....you will hear it come in....also check the rubber o ring isn't leaking ......buy a unysin about. 40 bucks to see the set up is correct .......ed
twincamman
PostPost by: RogerFrench » Mon Dec 09, 2013 1:20 pm
What are the other plugs like? What plugs do you use?
RogerFrench
PostPost by: Pistacchio sprint 72 » Mon Dec 09, 2013 8:56 pm
Plug number3 is on the left side of the picture for comparison. Colour is light brown so no problem i would say.
Plugs are iridium ix by ngk
Bpr7eix
4055
PostPost by: RogerFrench » Wed Dec 11, 2013 11:10 am
Possibly plug lead but I know yours are new so very unlikely to be a problem.
I agree that no. 3 looks OK. Twincamman identified the correct screw.
RogerFrench
