Rear Crank Cover Cork Gasket
PostPost by: AlfaLofa » Sun Dec 01, 2013 3:18 pm
Here's is a picture of an engine I have.
003.jpg and
It's has a Mk1 block with a 6-bolt crank.
I have a sump gasket kit - but the rear cork gasket appears to be too narrow for the rear cover.
The groove in the aluminium cover is approx. 7mm wide whereas the cork gasket is only about 4.5mm in width.
The rear cover came with the block - but I don't know if it is the correct cover.
So my question is what gasket set should I order which has a gasket for my rear cover :?: :?: :?:
Also in my gasket set is a (white) nylon washer with an ID of about 0.5" - where is this supposed go :?: :?: :?:
It's like the washer arrowed in this picture filched from SJ Sportscars.
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa
PostPost by: oldchieft » Sun Dec 01, 2013 3:50 pm
Looks like a cross flow cover to me.
My guess for the washer would be the sump plug!
Jon the Chief
oldchieft
PostPost by: types26/36 » Sun Dec 01, 2013 5:02 pm
Generally speaking the early Xflow used the same cork seals and cover as the 6 bolt TC but the later Xflow used a different cover and wider rubber seals (see pic) although I believe some TC's did have rubber seals.
I always fit the later Xflow cover as I believe the wider Xflow rubber seal is better.
The problem is if you buy the later Xflow sump set you will get the rubber seals but it will not fit on the TC front cover as this is still for the narrow cork seal.
I overcome this buy using some "O" ring section rubber to make the front seal as I do not like the cork seal.
Edit: just re-read your post and I see your cover has a 7mm groove so just went and measured the TC corks and they are 7mm (or near enough) so I dont know what your 4.5 mm cork is from :?
SUMP SEALS 006.JPG and
Mar10528.JPG and
SUMP SEALS 001.JPG and
SUMP SEALS 002.JPG and
SUMP SEALS 004.JPG and
types26/36
PostPost by: AlfaLofa » Sun Dec 01, 2013 5:40 pm
Hi Brian,
Thank you for your reply and the excellent photos.
Your photo of the recesses in the covers shows the groove in the twin cam cover as 7mm - which matches the measurement I took from the cover attached to my block.
So it begs the question - which rear cover does my 4.5mm wide cork gasket fit?
I fortunately also have a 711 rear cover - although I didn't know it was a 711 until your posting :wink:
Thus I think I might go with the 711 cover and a rubber gasket.
Brian in your last photo it looks as if the front rubber seal is slightly narrower than the rear. Could you please tell me if this front seal is about 7.75-8.00 mm wide? (If it is it will do just fine for the non standard groove in the AKS front cover).
AlfaLofa
PostPost by: types26/36 » Sun Dec 01, 2013 6:06 pm
Steve,
The front and rear rubber seals are about the same so maybe its the pic that is deceiving, here are some pics showing the size on the outside width and also the width between the raised section.
Then a pic of the inner section which has two "ribs"
If you want one pm me your address, I'm sure I have a few kicking about.
SUMP SEALS 007.JPG and
SUMP SEALS 009.JPG and
SUMP SEALS 013.JPG and
types26/36
PostPost by: G4ILN » Wed Apr 02, 2014 7:46 pm
I'm rebuilding my twin cam engine at the moment and have the exact same problem. The groove in my rear cover is 7mm wide and the groove in the front cover is 6.37mm wide. The cork seals in the gasket set are way too narrow at about 4.5mm wide. I've no idea what engine they were intended for. Perhaps they've been incorrectly manufactured or specified?
Looking through cork seals left over from previous rebuilds I found a suitable cork seal for the front cover, but I've nothing to suit the rear cover. Does anyone know of a UK supplier who has the correct cork seals? I guess I'm going to have to buy a complete sump gasket kit.
I must have had the sump off about four times in the last 40 years, mainly for water pump repairs, but I've never come across this problem before.
Thanks, Graham.
G4ILN
First Gear
First Gear
PostPost by: G4ILN » Wed Apr 09, 2014 11:22 am
I purchased a Payen gasket set from Burton Power and this had the correct 7mm width cork seals. The gasket set which had cork seals, which were too narrow, was unbranded.
Graham.
G4ILN
First Gear
First Gear
