A bit of an oil leak...
PostPost by: Johnfm » Sat Nov 30, 2013 7:25 pm
So, I realised I was getting a bit o leakage - my dynamo is covered in oil.
So I put some brown paper on the garage floor to catch the drips to see if I could isolate its source...
The whole engine!
This is a few days after two 8 miles drives.
1967 Plus 2 #0168
Johnfm
PostPost by: types26/36 » Sat Nov 30, 2013 7:39 pm
Oh dear.......the Torrey Canyon comes to mind :shock:
types26/36
PostPost by: Johnfm » Sat Nov 30, 2013 7:47 pm
Maybe I could sell it to a psychiatrist for use in Rorschach tests...
1967 Plus 2 #0168
Johnfm
PostPost by: ricarbo » Sat Nov 30, 2013 7:57 pm
Well, the wind will push it towards the back and gravity will spread it down, so I imagine it's at the front, above the dynamo. Front cover to cylinder head?
ricarbo
PostPost by: Johnfm » Sat Nov 30, 2013 8:03 pm
Probably.
Only one thing for it - sump off, head off seal front cover, new HG and new sump gasket.
1967 Plus 2 #0168
Johnfm
PostPost by: types26/36 » Sat Nov 30, 2013 8:14 pm
Naa.....engine out then you can replace the rear main oil seal, gearbox 1st motion shaft seal and fit the sump gasket with relative ease........but only my opinion :roll:
types26/36
PostPost by: Johnfm » Sat Nov 30, 2013 8:28 pm
I haven't got the setup for an engine out job. But it is tempting.
1967 Plus 2 #0168
Johnfm
PostPost by: oldelanman » Sat Nov 30, 2013 8:35 pm
Johnfm wrote:I haven't got the setup for an engine out job. But it is tempting.
http://m.hss.com/mt/www.hss.com/g/67715 ... Crane.html
I'm with Brian....
S4 DHC
PostPost by: types26/36 » Sat Nov 30, 2013 9:01 pm
Got to say I'm not keen on cranes....a bit iffy as legs usually dont usually fit under/around the narrow track on Elans and despite the folding facility they always seem to be in the way (unless you have lots of garage space)
My preference is for the trusty old block & tackle and they are even available with an electric option :lol:
OK....you need a beam to hang it from but most garage beams will take the weight of a TC engine (even if you remove the head and ancillaries first) ....and to quote a recent thread " drain the oil to reduce weight" :lol:
BLOCK AND TACKLE 003 (Copy).JPG and
types26/36
PostPost by: oldelanman » Sat Nov 30, 2013 9:26 pm
S4 DHC
PostPost by: types26/36 » Sat Nov 30, 2013 9:33 pm
1291131680_two-thumbs-up (Copy).jpg and
types26/36
PostPost by: Quart Meg Miles » Sat Nov 30, 2013 9:37 pm
Second-hand tool shops will have manual chain-hoists at weekend hire rates. They are easy to maintain in my experience.
But first Gunk the oil off your engine so that you can see where it is coming from, it may be only one place.
Meg
Quart Meg Miles
PostPost by: Johnfm » Sat Nov 30, 2013 10:32 pm
Quart Meg Miles wrote:Second-hand tool shops will have manual chain-hoists at weekend hire rates. They are easy to maintain in my experience.
Engine is pretty clean. I have hand cleaned it all. I think most of it is coming from the front left.
The problem is the oil is so clean it is hard to see a source, but the dynamo is smothered in oil. I don't think it is coming fom the dipstick.
If I resist the temptation to mess about with the head, valves, cams I etc I could probably do the head, sump and front cover in a few nights after work.
1967 Plus 2 #0168
Johnfm
PostPost by: Johnfm » Sun Dec 01, 2013 11:03 am
Used new piece of paper last night.
After 3 mile drive I parked up.
Two drip zones:
Back of sump. Gravity is moving oil to rear of sump where it drips.
Edge of bell housing. Where clutch line is clipped to the housing. Not sure how it is getting there. The starter motor is a bit oily, so maybe there is a leak near there.
Or is there a rear main seal of some sort?
1967 Plus 2 #0168
Johnfm
PostPost by: types26/36 » Sun Dec 01, 2013 11:08 am
There is the rear crankshaft seal (engine out job) but just check the rubber oil return tube (above petrol pump) which is a common leak and it can be replaced with the head still on.
types26/36
Next
Users browsing this forum: No registered users and 53 guests
