Yorkshire engine builders?
PostPost by: Johnfm » Mon Nov 18, 2013 12:21 pm
Who can I call in Yorkshire to get a quote on heam skimming/new guides/new valves etc?
1967 Plus 2 #0168
Johnfm
PostPost by: elanman999 » Mon Nov 18, 2013 1:08 pm
John,
Try Amac Engineering in Northallerton. 01609 779600. I use him for all the bits that I can't do myself.
elanman999
PostPost by: tonyr27 » Mon Nov 18, 2013 1:26 pm
Which part of Yorkshire are you?
TonyR
1966 S3 FHC Medici Blue
tonyr27
PostPost by: jono » Mon Nov 18, 2013 2:10 pm
If you would deign to look outside of the Peoples Republic of Yorkshire (valid passport permitting), this would be a good choice:
http://raceengine.co.uk/
PostPost by: Johnfm » Mon Nov 18, 2013 3:17 pm
Cheers all.
I am in Leeds just just need a ball park for a skim/revalve just in case I need to do it.
If it is megabucks, I will jsut leave the head until I need to do it. If is it <?500, I might be tempted in the new year.
1967 Plus 2 #0168
Johnfm
PostPost by: elanman999 » Mon Nov 18, 2013 4:32 pm
John,
Your head gasket problem is another issue but once you get inside the head things tend to get expensive, if you want a good job done that is. So I would run the car and see how is goes. If it goes OK and does not run oil down the guides then I would leave the valves etc as they are.
Others may have different suggestions.
And Jono is correct there are places outside Yorkshire, though that is hard to believe. :lol:
elanman999
PostPost by: jimj » Mon Nov 18, 2013 5:04 pm
I had my head done in Yorkshire, around ?200 3 or 4 years ago for crack testing, skimming, valve seats etc. Almost inevitably, these days, I can`t remember the name but it was in Sheffield about 100 yards north of the Leppings Lane entrance to Sheffield Wednesday (football club).
Jim
PostPost by: DavidLB » Mon Nov 18, 2013 6:51 pm
I would recommend raceengine as well
DavidLB
PostPost by: Johnfm » Thu Nov 21, 2013 4:29 pm
Dilemma really.
Car doesn't seem to blow the tiniest puff of oil - neither cold, nor hot, idling or under acceleration.
Peeking into the spark plug holes, the pistons aren't covered in black gunk.
The compression numbers are good.
The valve clearances on CYl1 inlet and exhaust are below spec and should be increased.
There is a decent oil leak (not seemingly from the dipstick) that is covering the alternator in oil and, after a 4 mile run, there is a lot of oil dripping from the sump (looks liek it has blown there from somewhere up ahead.
I think the oil is leaking from the head gasket area at the front of the engine.
Do I man up and remove the head to fix the oil leaks?
I do not have the budget to add big valves etc - so will jsut send head off for crack testing and skimming.
1967 Plus 2 #0168
Johnfm
PostPost by: jono » Thu Nov 21, 2013 5:43 pm
John,
Just pull the head and do the gaskets, if I can do it anyone can :)
The bits (oil, coolant and gaskets) will cost less than ?100 and you will also get to know a bit more about what you have.
PostPost by: pharriso » Thu Nov 21, 2013 6:48 pm
Johnfm wrote:Dilemma really.
It ain't broke, don't fix it!
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: MickG » Thu Nov 21, 2013 8:33 pm
As above really. However from your previous posts I would get the valves sorted. The clearances you have posted could lead to burnt valves. Get the engine steam cleaned so you can see exactly where any oil leaks are comming from. Then decide.
Regards Mick G
MickG
PostPost by: Johnfm » Fri Nov 22, 2013 11:35 am
jono wrote:John,
See my new thread.
I think I will.
I can do all the removal.
I have a mechanic who will come to my house to refit at ?20/hr - so it is a no-brainer really.
Will check your posts for any horror stories though!
1967 Plus 2 #0168
Johnfm
PostPost by: john.p.clegg » Fri Nov 22, 2013 12:03 pm
Edit...Moved
John :wink:
Users browsing this forum: MoBoost, pptom, richardl46 and 31 guests
