Flywheel
PostPost by: gino1 » Mon Oct 07, 2013 6:52 pm
Hi all....anyone got or can give me the
drawing of the holes and dowel postions for a 6 bolt flywheel...i have a 6 bolt flywheel but no dowel holes on it.
Gino
Milano
Italy
1964 Elan S2 Roadster
1965 Elan S2 Roadster
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
gino1
PostPost by: oldchieft » Mon Oct 07, 2013 8:48 pm
I would decide what clutch cover I am going to use and then dowel accordingly.
I am running a Sierra clutch as it goes with the Sierra box.
Just remember to get the doweling and trial build done before balancing.
Or better yet get it done by the shop that does the balancing.
Jon the Chief
oldchieft
PostPost by: john.p.clegg » Mon Oct 07, 2013 9:20 pm
Gino
Can you not take them from the crankshaft?
John :wink:
PostPost by: gino1 » Tue Oct 08, 2013 5:38 am
Hi John,
Yes I can but if someone has them it would be easier :D 8)
Gino :wink:
1965 Elan S3 Coupe
1968 Elan S4 Coupe
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1
PostPost by: rgh0 » Tue Oct 08, 2013 6:24 am
Hi Gino
Six bolt flywheels did not use a dowel pin as standard and had no hole for one. Some (all?) standard six bolt cranks had a hole for a single dowel but it was not fitted.
If your crank does not have dowel hole(s) I personally would not worry about fitting them. If it does then I would base it on the crank itself with a press fitted item like this as like they say "dimensions may vary"
PostPost by: Jeff@Jae » Wed Oct 09, 2013 4:19 pm
As Rohan said, don't worry about it. Simply mark crank/flywheel for correct position after balancing.
Jeff@Jae
