Temperature Capillary sensor
PostPost by: Watership Down » Thu Oct 03, 2013 7:14 pm
Temp sender.jpg and
Anyone know if these are available or do I have to look at some other means of temperature measurement. i have a dual gauge (oil pressure/water temperature)
Watership Down
New-tral
PostPost by: RogerFrench » Thu Oct 03, 2013 7:37 pm
Yes, they are available. You have options - one is to repair the one you have, and this write-up can help.http://www.ply33.com/Repair/tempgauge
Another choice is to send it off for repair, recalibration, what-have-you. Nisonger Instruments or Gaugeguys will do that for you. I've used both - they are both good in my opinion. They could also supply you with a new gauge if you choose.
RogerFrench
PostPost by: RogerFrench » Thu Oct 03, 2013 7:40 pm
Another choice is to send it off fro repair, recalibration, what-have-you. Nisonger Instruments or Gaugeguys will do that for you. I've used both - they are both good in my opinion. They could supply you with a new gauge if you choose.
RogerFrench
PostPost by: billwill » Fri Oct 04, 2013 1:26 am
See my trials & tribulations with the temperature gauge starting here:
lotus-elan-f19/getting-ogu-roadworthy-again-t26101-15.html#p172491
I shall probably have a go at getting more ether into the bulb over this winter.
