My Zetec +2 project update
I started posting my Zetec project under the name " my modified early spyder chassis". The project has moved on since and I finally drove the car out of the garage today.
Here are a few pictures of the car so far
- Netec99
Looks terrific; a lot of thought & hard work gone into that for sure.
Beware of the Illuminati
Fantastic job! Not only beautifully accomplished but your timeline is amazing to one who is moving at a much slower pace. You inspire me!
Your pictures answer my question, "Can painted bumpers be made to look good on a +2?" They sure can. I also like the de-chromed look of your grill opening and, as stated above, you've nailed the ride height. Very well done.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
rgh0 wrote:You appear to have got the ride height around original (or perhaps even lower) compared to many plus 2 Zetecs that are jacked up for ground clearance under the sump and exhaust. What have you done to achieve that?
Hi Rohan,
Because I'm using an original modified Spyder chassis, I have been able to use fully adjustable shocks front and rear.
The ground clearance is OK, but I do need to be very careful over some speed bumps. I could raise it higher, but I think it will spoil the look.
regards
Rob
- Netec99
Thanks John,
When I want to pimp my ride, I know who to contact
Rob
- Netec99
How have you dealt with the sump and exhaust manifold? These are the two things that usually stop +2 Zetecs from being able to sit at that ride height! I see you used an Escort Zetec sump, and you mention modifying it - what did you end up with? Grinding a bit of the ally away, and also dropping the ARB?
Your car does look the business, though - congratulations, you must be delighted!
1965 Elan S2
1972 Elan +2S 130
1972 Elan +2S 130
- ElanSeries2
Rob
I am also embarking on an early Spyder chassis rebuild just as yours. Very interested in your Gaz adjustable upgrade. Can you post make and model of those for me ?
Netec99 wrote:rgh0 wrote:You appear to have got the ride height around original (or perhaps even lower) compared to many plus 2 Zetecs that are jacked up for ground clearance under the sump and exhaust. What have you done to achieve that?
L
Hi Rohan,
regards
Rob
LaikaTheDog - Third Gear
