No bore thickness stamp
My S1 engine doesn't have the bore thickness stamp that many sources say it should and I was wondering if that is common. At the point where the stamp should be I have a small stamp of b over 248 with a circle around it. The engine block number appears to be LB1832. I'm sure the engine is the original four bolt crank.
Thought's please?
Kurt
26/3754
Thought's please?
Kurt
26/3754
- nomad
Kurt
Your Elan left the factory on 30 July 1964, fitted with engine no LP1832. 'Fraid I have no record of the bore thickness. I'm not sure if they were stamped on the early blocks or not - anyone?
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Anything stamped on piston crown? If it's been rebored and oversized pistons fitted there may be......
- robertverhey
Robert:
Cylinder bore measures stock and pistons have "front" stamped on the crown and that is all I believe. I'm quite sure that the engine has never been apart. The car was last licensed in 1980.
Tim: I appreciate that information, I believe there are some build changes around that time though I don't remember what they were right now.
Kurt
26/3754
Kurt
26/3754
- nomad
